SMath Studio Forum
Bugs & Problems
Unicode issue in string argument for image2rgb()
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 829 time(s) in 525 post(s)
Hi. The error is self explained. This is the saved file: Best regards. Alvaro.
Thank you, I'll fix it ASAP. |
Fixed and released for the latest beta |
Originally Posted by: Davide Carpi Fixed and released for the latest beta Hi Davide. The issue persists for release "0.99.7786.571": test.sm (3kb) downloaded 7 time(s).Best regards. Alvaro.
It works for me even if dots, slashes and underscores are encoded |
Originally Posted by: Davide Carpi It works for me even if dots, slashes and underscores are encoded
Hi Davide. Yes. you're right, it works with encoded strings now, I see the strings, and no check if can read files with that. So, standard ASCII characters lower than 128 will be encoded as Unicode? That can introduce a lot of issues for low level manipulation to the user. test_unicode_2.sm (6kb) downloaded 7 time(s).Also, the string "a_b" doesn't appear in the search box, but if you search for x, x and "x" appear. Also, suppose that I want to find an sm file where it's defined the function "my_function_1": I need to search now the string "my\005F\function\005F\1" inside the files? Best regards. Alvaro. Edited by user 26 April 2021 14:56:01(UTC)
Originally Posted by: Razonar So, standard ASCII characters lower than 128 will be encoded as Unicode? That can introduce a lot of issues for low level manipulation to the user. As Andrey has stated there's an enforcement on the encoding, I don't know how much can be relaxed (as positive thing now you should be able to use 4-digits folders in paths); however as you pointed out in some fields the program misses the proper implementation to deal with them (more visible because the enforced rule, but would have been buggy even with less strict approach, and it was buggy since the encoding was already in place). Ideally it should works flawlessy whatever under the hood all character are encoded or not. |
on 26/04/2021(UTC), on 26/04/2021(UTC)
Alvaro, Originally Posted by: Razonar Also, the string "a_b" doesn't appear in the search box, but if you search for x, x and "x" appear.
Also, suppose that I want to find an sm file where it's defined the function "my_function_1": I need to search now the string "my\005F\function\005F\1" inside the files? Thank you! Fixed. Edited by user 26 April 2021 18:09:39(UTC)
SMath Studio Forum
Bugs & Problems
