SMath Studio Forum
Questions
Angles trygonometry value in solutions of the system of equations
Hi, How to turn of the decimal values in trygonometry angles value? I got sth lik this for solution of system of equations: The file with example: example_v1.sm (9kb) downloaded 8 time(s).Regards, A.
You can use the function al_nlegsolve with any initial assumptions (because the equations are linear) al_nlegsolve.sm (12kb) downloaded 13 time(s).
Originally Posted by: Astroneus How to turn of the decimal values in trigonometry angles value ? By default, trig are in decimal radian in all CAS. Recast your solutions, fill-in the unit place holder.
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 830 time(s) in 526 post(s)
Hi. You also can use Maxima commands, in this case ev(): Best regards. Alvaro. Edited by user 10 September 2021 05:27:41(UTC)
Hi Martin. I use Maxima's ev() because SMath's Assign() only works with the variable names, instead others, like xo, yo, and SMath's at() doesn't works for the symbolic evaluation, as shown this picture: example_v1.sm (16kb) downloaded 6 time(s).This is a workaround for use only SMath native functions or plugins, without any explicit Maxima function: example_v2.sm (16kb) downloaded 7 time(s).Best regards. Alvaro. Edited by user 10 September 2021 19:15:21(UTC)
| Reason: workaround added
SMath Studio Forum
Questions
