SMath Studio Forum
Questions
how to use the "system of equations" function
Hi, guys: I'm a new one to SMath. and have a question on system of equations. here is a simple question how to get the result of x, y without using the matrix? I tried solve and findroot, but can't get the value of x, y. Thank you for the help Happy New Year!
Originally Posted by: johnpan how to get the result of x, y without using the matrix? I tried solve and findroot, but can't get the value of x, y. You can't use solve() for nonlinear equations. (more than one unknowns) You can use roots(), FindRoot() or al_nleqsolve(). Here is your equation solved in various ways. Regards solvers.sm (11kb) downloaded 18 time(s).Edited by user 01 January 2022 14:14:27(UTC)
Originally Posted by: johnpan how to get the result of x, y without using the matrix ?
Matrix style is more commonly encountered in Engineering projects. That add-on will enrich your future projects.
Excellent reply! FindRoot is better for my condition, I need units. Thanks Overlord! Originally Posted by: overlord Originally Posted by: johnpan how to get the result of x, y without using the matrix? I tried solve and findroot, but can't get the value of x, y. You can't use solve() for nonlinear equations. (more than one unknowns) You can use roots(), FindRoot() or al_nleqsolve(). Here is your equation solved in various ways. Regards
Thank you, Jean, you're right, I need more practice. Originally Posted by: Jean Giraud Originally Posted by: johnpan how to get the result of x, y without using the matrix ?
Originally Posted by: Jean Giraud Matrix style is more commonly encountered in Engineering projects. That example has only one CAS route ... naturally 15 D.
SMath Studio Forum
Questions
