Text region background color don't uniformly applied when it contains an inline formula. This bug occurs on linux, don't know the current situation under windows. Regards textregion_bug.sm (4kb) downloaded 8 time(s).
confirmed also for win10
sergio Edited by user 08 January 2022 18:08:54(UTC)
... SS 6179
Originally Posted by: Jean Giraud ... SS 6179 SMath v6179 don't have inline formula usage in text regions. Your sample is useless for this bug, has wrong information.
Originally Posted by: overlord SMath v6179 don't have inline formula usage in text regions. You can have it lot more productive for publishing Formatted Label.
Originally Posted by: Jean Giraud You can have it lot more productive for publishing Formatted Label. No I won't be more productive. Bug is related with text region under latest smath releases. There is no relevance with Formatted Label. I demand you to stay with subject.
Originally Posted by: overlord Bug is related with text region under latest smath releases. Designers may appreciate You specify from which latest release s
No one uses old releases except you. So when a new bug is defined it is either in last stable or nightly build. Developers know what to do, they don't need your suggestions to understand. Edited by user 09 January 2022 02:01:40(UTC)
This bug still remains.
