Originally Posted by: loha I find Jean's unitless calculations very very elegant and fascinating.
Problem is, his calculations are hard to read. Harder to understand, illogical to revise since they are bound to certain units.
Everything is everywhere, they are color racket and there is no heuristical walkthrough in his samples.
There are even some converting numbers, strain you to understand where they come from
Which those convert numbers would be redundant if he bothered to use embedded units.
Those numbers doesn't look not very elegant on page, and not knowing where they come from at first glance is not fascinating.
And sometimes that numbers tend to make serious mistakes, like that
kW/hr pump power calculation of his.
Not even a typo, he divided 1hr (3600s) to g.e (9.8), found 367 and used it in that abomination.
I have never seen that kW/hr usage anywhere, but interestingly his pump power results have it.
It should even be kW, not even kW*hr. What will be benefit of pump electrical consumption calculation?
Originally Posted by: loha Everything that works, and is understandable, is good, very good!
Real problem is, some of his engineering calculations, especially unitless ones, have some serious mistakes.
Most of his viscosity related calculations are wrong due to his lack and denial of unit usage.
If he bothered and learned how to use units, he would see engineering is not just operations on given numbers.
Units and their relations are also very important to obtain correct answer at the end of some calculations.
Originally Posted by: loha We don't need to be dogmatic, or to be arbiters of taste.
We wouldn't, unless he didn't propagate new users about his ridiculousness.
He wrongly claim SI units are not for engineering calculations.
I don't know what the hell this statement means, everyone in the world uses SI now.
He can use whatever he want, I personally won't care. He is a lost case.
But encouraging new users (also possibly young students) non-scientific, incorrect and illogical ways is unacceptable.
Originally Posted by: loha I don't understand: imperial is "included" in "SI-derived units? Is that what you mean?
Imperial units are defined by metric (SI) units nowadays. That's what he meant.
For example, take an inch. An inch is now defined by its metric equivalent. 1 inch equals 25.4mm, nothing else.
No platinum-iridium bar used to define an inch, feet, etc now. Imperial units are based on metric units now.
Same can be said for weight definitions of imperial units or any other distinct units.
By the way, every SI unit has now abandoned man-made artifacts to define them.
https://www.youtube.com/watch?v=SmSJXC6_qQ8https://www.youtube.com/watch?v=hid7EJkwDNkOriginally Posted by: loha All the engineers I know - use all sorts of units: kg/cm2, MPa, tonne/m2... and they don't even care about the difference between 9.81 and 10, so 1kg = 10N and that's all !
All units you wrote are actually SI units. So we are saying the same thing. Using SI units will prone to less errors.
And conversions like that can be done when it is negligible, but it doesn't mean it is correct for every scenario.
It may be usable on earth, when you are going to use that conversion earth off-surface, it will definitely be wrong.
Originally Posted by: loha Like the definition of the stress block, defined in 2D, the depth being implicit. So, applied strictly, the formula is badly wrong, lacking one dimension!
This is because of negligibleness when practical calculation usage is enough.
When simplification of certain functions to a certain degree won't effect the result that much, it can be done.
If you are not writing a scientific paper about stress block, there is no need to include every aspect or dimension to it.
A simplified function won't be totally wrong, it will be "correct enough".
Originally Posted by: loha I am not annoyed by his bittersweet/ironic remarks here and there.
Well, we do. He makes serious mistakes and doesn't accept his failure in almost all cases.
Yet he mock requests, questions, samples, replies, try to hijack peoples topics, spam forum with same answers.
There are 10 page result if you search Colebrook, this is just ridiculous.
He once replied a question with four identical ensuing answer. Not a polite behavior.
Sorry for wall of text, Regards.
