SMath Studio Forum
Questions
Vectorize Issue: How to Get 2D Matrix Output?
Originally Posted by: overlord Download Kirby NIST data set ... fit. I will correct your defective design. . Just that one for learning step.
Originally Posted by: Jean Giraud Just that one for learning step. Yeah, you should learn there is no such thing as kW/hr. Unit of power is kW, it is written as kilowatt. No time involved. And poise is the unit of dynamic viscosity. (Pa*s) or (kg/m*s) In pump calculation you should use stokes. (m^2/s)
Joined: 01/04/2020(UTC) Posts: 85 Location: Wellington Was thanked: 4 time(s) in 3 post(s)
Originally Posted by: Jean Giraud Originally Posted by: overlord Download Kirby NIST data set ... fit. I will correct your defective design. . Just that one for learning step. It would have been a really fast learning step if SMath's units were used from the outset. Time for an apology and a retraction (SI units being unsuitable for process control) Jean, me thinks. This has not been pleasant to watch.
Originally Posted by: marks2c Time for an apology and a retraction (SI units being unsuitable for process control) Jean, me thinks. Yes Mark, adapt project system/standards, accordingly to the Control Engineer Tool Box ... standards Nothing dogmatic/Bible. Cheers ... Jean.
Originally Posted by: Jean Giraud Originally Posted by: marks2c Time for an apology and a retraction (SI units being unsuitable for process control) Jean, me thinks. Yes Mark, adapt project system/standards, accordingly to the Control Engineer Tool Box ... standards Nothing dogmatic/Bible. Cheers ... Jean. Excellent, thanks Jean. It may be worth doing some weeding to remove examples that may lead noobies astray.
SMath Studio Forum
Questions
