SMath Studio Forum
Questions
Sys to vect and the other way around
Joined: 12/04/2022(UTC) Posts: 11 Location: Guadalajara
Dear friends, is there a function to convert a "sys" to a "vector" and a function to convert a "vector" to a "sys"?
Originally Posted by: Mario Acevedo Dear friends, is there a function to convert a "sys" to a "vector" and a function to convert a "vector" to a "sys"? mat2sys(), mat2sys.1() sys2mat(), sys2mat.1() These are the functions you need. You will need to install Custom Functions plugin for those. Regards
... you may not need the transition.
The Unwrap(M) algo is commonly used in projects.
Originally Posted by: Jean Giraud The Unwrap(M) algo is commonly used in projects. Unwrap() is not what owner of topic asked. Non-relevant.
Originally Posted by: Mario Acevedo Dear friends, is there a function to convert a "sys" to a "vector" and a function to convert a "vector" to a "sys"? There is a good reason to collect a project in system. You can add/remove ... once collected or at time of collection. ... augment by clicking on the place holder of system. ... push down from top ... insert . The attached example was collected this way by the Originator. Simply plotting a zombie parrot from conversion. At this point, the appropriate adjacency matrix was designed, resulting in the desired W truss. Collaboration appointed several visits ... done. If you have something specific on the design board, let's go. Cheers ... Jean. Page9 sys2mat.sm (25kb) downloaded 14 time(s).
SMath Studio Forum
Questions
