Offline RAMDass
#1 Posted : 16 February 2023 02:31:19(UTC)
RAMDass
United States
I run the mono version of Smath Studio on KDE Linux. I attempted to update version 0.99.7822 but all more recent mono versions will not launch from the desktop file (but I can run them from the terminal line using 'sudo mono SMathStudio_Desktop.exe'.) My desktop file is set to run SMathStudio_Desktop.exe as root; this works fine for version 0.99.7822.
Also, it appears that recent versions require a version of .NETFramework that Mono does not provide.
So far, the 2021-era version is sufficient for me; I just wanted to register these problems. And thanks! I am keeping calm and calculating.Good
Offline overlord
#2 Posted : 16 February 2023 04:01:47(UTC)
Turkey
I take you are using KDE Neon, which is debian based.
Debian based distros have a mono bug, caused by glibc.
Not only SMath, some mono programs don't work also without sudo.
So far only debian or ubuntu based distro I could
make all mono programs run without sudo is MXLinux (ahs).
It has a linux kernel v6+ and an updated glibc also.
Maybe this is the reason why it works and LTS versions are not.
I will download your OS and check in a VM if this is the reason.
And for desktop file issue, file/script below is what I use.
I use a dark theme but SMath doesn't look good with it.
Script also change theme to a light one just for SMath.
smathstudio_desktop_mono.tar.gz (1kb) downloaded 3 time(s).
Code:
#!/bin/sh
HERE="$(dirname "$(readlink -f "${0}")")"
cd "${HERE}"
GTK2_RC_FILES=/usr/share/themes/Raleigh/gtk-2.0/gtkrc exec mono "${HERE}//SMathStudio_Desktop.exe" "$@"
Offline overlord
#3 Posted : 17 February 2023 23:11:37(UTC)
Turkey
I tried SMath official appimage with latest stable KDE Neon under Qemu.
It worked flawlessly. No issues with starting, installing plugins, etc.
SMathStudioDesktop.1_0_8348.x86_64.ubuntu-22_04.glibc2.35.AppImage
