Dose anyone know why using the function expand of maxima dosent work? Thanks
Any example of the problem? Use the paperclip button to attach screenshots. |
Originally Posted by: mkraska Any example of the problem? Use the paperclip button to attach screenshots. Al usar el comando expand de maxima no ejecuta nada ejemplo
You have to use the functions correctly and you need to set optimization to None, otherwise SMath messes up the returned expression from Maxima. Worksheet21.sm (4kb) downloaded 21 time(s). |
