Generally, experimental projects will collect noisy measured values ... call them tabular values. Collect plenty to be representative. This document is a guide line to projects that produce clean discrete. For clean D3 data set must have 6 decimals at least. 1. F.B.Hildebrand is kind of 'yardstic' ... D3 has dropped from 101/78. 2. Discrete convolution is unscaled ... NOT offered. 3. Ridder agrees closely with Hlidebrand. If you have hyper noisy data, low populated [Corn Thermies] smooth wisely ... possibly fit, populate ... suite. Maths Derivative Ridder DEMO Copy.sm (133kb) downloaded 21 time(s).
