Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 339 Was thanked: 26 time(s) in 25 post(s)
There is an interesting one class of geometric optimization problems, a couple of which are described here. http://www.twt.mpei.ac.ru/ochkov/Acad-Hat.pdfAttached and as a picture SMath solution for one such problem. I offer SMath-fans such optimization problems. • a cylinder with a hemispherical bottom and a flat round lid; • cylinder with hemispherical bottom and without cover; • a cylinder partitioned off by an inclined elliptical partition so that the vertices of the elliptical partition touch the edges of the circles forming the bottom and the lid of such a container; • cone without cover (with and without vertical baffle); • cone with lid (with and without vertical baffle); • a cone covered with a hemisphere (with and without a vertical baffle); • a truncated right circular cone with a small base diameter half that of the large base; • a truncated straight circular cone with the area of the small base half as large as the area of the large base; • the lower part of the cylinder, dissected by a plane so that it passes through the edge of the circle forming the lid at the top, and at the bottom through the diameter of the circle forming the bottom; • the upper part of the dissected cylinder described above. Come up with other similar containers with two parameters to optimize them with constraints. The task can be simplified - reduced to a flat one. A rectangle with a minimum perimeter length and a given area is a square. And what happens if you do not take into account one side of the square (an inverted letter P with an area limited by three sides)? And what will happen if we make a partition for such a “flat container” and turn it into the letter Ш? They must be solved analytically. If it does not work out, then numerically Cylinder-Square.sm (269kb) downloaded 24 time(s).
1 user thanked OchkovVF for this useful post.
