SMath Studio Forum
Bugs & Problems
Printed documents from viewer don't show values correctly
Joined: 26/05/2013(UTC) Posts: 21 Was thanked: 1 time(s) in 1 post(s)
In some cases the values in the printed document don't match up with the values of the viewer. See attached images as example. Edited by user 12 March 2014 09:55:46(UTC)
| Reason: Not specified experimentator attached the following image(s): |
Learning by doing |
Thank you! I will check it.
SMath Studio Forum
Bugs & Problems
