Offline gth802s
#1 Posted : 20 December 2023 05:55:54(UTC)
gth802s
Rank: Member
United States
Was thanked: 2 time(s) in 2 post(s)
Hi all, I am putting together a quick worksheet to calculate factor of safety against soil liquefaction triggering. As I have been going step-by-step and defining the various variables, I noticed that all the calculations take place more or less instantaneously, whereas the last variable I defined (N1_60cs) seems to take a relatively long time to calculate (approximately 12 seconds on my machine). The worksheet I have so far is attached.
Any thoughts as to what is causing this? Thanks in advance!
Seismic Site Class & Liquefaction Potential.sm (125kb) downloaded 7 time(s).
#2 Posted : 20 December 2023 06:50:59(UTC)
select all > optimization > numeric
AND EITHER
z:z
OR
z:+line(...)
This is because z:line() is a procedure (something like a function, but for variables); it doesn't evaluates in place on definition, hence is completely calculated from scratch every time you need z, z[j], etc....
Using a + between the definition operator and the line() function, you don't have anymore a procedure; using z:z, it evaluates once from that point onwards.
Seismic Site Class & Liquefaction Potential_num.sm (125kb) downloaded 7 time(s).
Edited by user 20 December 2023 07:23:06(UTC)  | Reason: clarification
Offline gth802s
#3 Posted : 20 December 2023 07:01:15(UTC)
gth802s
Rank: Member
United States
Perfect, that works!
Much appreciated as always!
#4 Posted : 20 December 2023 07:23:18(UTC)
You're welcome!
#5 Posted : 20 December 2023 07:30:22(UTC)
Your last for/loop, as given, takes 32 s
isolate the three components
a:=eval(a) , b:=eval(Cool ...
timing drops 4 s
Offline Razonar
#6 Posted : 20 December 2023 08:07:23(UTC)
Razonar
Uruguay
Was thanked: 829 time(s) in 525 post(s)
Hi. This is another option, without numeric optimizations. You don't need to use line in your calculations. As Davide says, that makes the calculations faster to SMath.
Seismic Site Class & Liquefaction Potential.sm (123kb) downloaded 7 time(s).
Bes regards.
Offline gth802s
#7 Posted : 20 December 2023 09:15:47(UTC)
gth802s
Rank: Member
United States
Thank you, Alvaro! I like having the lines because it makes it clearer as to which parameter I am defining. I just didn't realize it was slowing it down so much (although putting + in front of the lines makes the problem go away - sort of a win-win!).
Thanks again.
Bes regards.
Offline overlord
#8 Posted : 20 December 2023 09:16:36(UTC)
Turkey
Another issue is, all calculation can be done under one for() loop.
If data matrices is much longer and not 10, this would benefit too.
However, the way it is written look much nicer and cleaner.
Offline Razonar
#9 Posted : 20 December 2023 18:07:29(UTC)
Razonar
Uruguay
Hi. You can eliminate all the for loops using the SMath index vectorization, which work more or less like the same concept in matlab, with cases() for having some visual separation
Seismic Site Class & Liquefaction Potential v2.sm (120kb) downloaded 4 time(s).
Similar Topics
Very slow calculation time (Questions)
by Lucas_MSA 17/11/2021 17:52:00(UTC)
Very slow calculation (Questions)
by hrwang 29/04/2021 12:13:23(UTC)
Sometimes VERY slow calculation time in program loops (Questions)
by themzlab 15/02/2017 17:52:49(UTC)
