Rank: Advanced Member Groups: Registered, Advanced Member Joined: 06/04/2023(UTC) Posts: 348 Was thanked: 28 time(s) in 27 post(s)
How can you in an attachment? PreClean.sm (64kb) downloaded 9 time(s).
Some numbers can not be calculated for D(). Iteration doesn't concluded because "≉". I have replaced it with an epsilon. To plot it is better you eliminate units. X-Y plot can but 2D plot cannot plot with units. I had to put plot under an eval(). Regards PreClean_fast.sm (64kb) downloaded 5 time(s).Edited by user 22 December 2023 13:19:02(UTC)
Joined: 28/08/2014(UTC) Posts: 1,369 Was thanked: 829 time(s) in 525 post(s)
Hi. Just use the recent Davide solution: Ctrl-A for select all, right mouse click and choose numeric optimization. The calculus is done in less than one second.
Best regards. Alvaro.
Originally Posted by: Razonar Hi. Just use the recent Davide solution: Ctrl-A for select all, right mouse click and choose numeric optimization. The calculus is done in less than one second.
Best regards. Alvaro. Edited by user 22 December 2023 16:22:00(UTC)
Originally Posted by: Razonar Ctrl-A for select all, right mouse click and choose numeric optimization. I did this first but doesn't work for my setup. I don't know why, maybe because I use linux.
