Joined: 21/11/2023(UTC) Posts: 24 Was thanked: 2 time(s) in 2 post(s)
Hi all, there seems to be no function similar to the Excel function "AverageIf" in SMath. Let me set up a hypothetical example with two vectors: z = [1 2 3 4 5] M = [50 50 25 20 30] Let's say that I want to calculate the average value of M for z => 3 AND z <=5. In this case, it should be (25+20+30)/3=25. What would be the best way to go about this? The "Mean" function in SMath returns the mean of the whole vector, so when I write a For loop with an If condition to extract values of M for the interval z, I don't know how to assign "blank" values to the cells that fall outside the defined range so it doesn't affect the average if it makes sense. What I then get is (0+0+25+20+30)/5=15 Thanks in advance as always! Edited by user 28 December 2023 09:56:39(UTC)
Aha, that should work.
Thanks!
This is another way. Regards AverageIf.sm (6kb) downloaded 3 time(s).
Took me a couple of minutes to wrap my head around this one, but now it makes sense. Thanks!! Originally Posted by: overlord This is another way. Regards AverageIf.sm (6kb) downloaded 3 time(s).
This maybe an easier way. Regards
