SMath Studio Forum
Questions
how to change result units to normal
Hello as in the title, how to change the result units to normal, previously I had normal results in integers, now the results have changed, for example (21761.554+5474.6904*i) these are electrical calculations Regards
Joined: 11/01/2018(UTC) Posts: 134 Location: Wisconsin Was thanked: 62 time(s) in 39 post(s)
Greetings, I rarely work with complex numbers, but it is work noting that SMath does have two functions: - Re() = "Returns the real part of a complex number."
- Im() = "Returns the imaginary part of a complex number."
Hopefully you can use these functions to generate the normal value you seek May this be of Good Help; ⚜ Kenny Lemens, P.E. ᵂᴵ |
SMath Studio Forum
Questions
