Hi everyone, I tried resolve the problem with units in "if" function but I cant. The formula is: The b value is not resolved and has no units. What is wrong? What should I to do to fix it? Janusz Janusz attached the following image(s):
You compare b.0 (length, 2.55 inches) to unitless 0.25 (what? meters? picas? kilograms?). You should: 1. Compare unit-wise (if b.0<=0.25*'in) 2. Remove units in "else" clause to make unitless result (if you need it like that): 2.52*sqrt(b.0/'in) or, alternatively 2a. Use units in first option (before "else" ): 1*'in, AND restore units in "else" clause": 2.52*sqrt(b.0/'in)*'in Edited by user 10 December 2014 12:45:58(UTC)
Best regards, Mike Kaganski |
Works perfectly! Thank You! Janusz Janusz attached the following image(s):
