Is it possible to control the scale of the graph axes, using code within the document or an option somewhere. I'm trying to make the scale conform to a specified domain and range so the graph generated by my functions doesn't have to be manually adjusted every time a variable is changed.
Best Regards,
Santiago
Hello Santiago, For precise scaling/limits you have to use a plugin, such as Maxima plugin ( examples) or X-Y Plot RegionA further help is inside the extension mangager ( Tools > Plugins...) > Interactive handbooks; here there is the SMath Studio Handbook, that contains a Graphics section. (You have to download it, set it to use as default, then will be available from the Help > Reference book... menu) Edited by user 14 March 2015 01:32:19(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
