Hi When I do the following, the results are not correct: Here is the file I used: Fault.sm (3kb) downloaded 11 time(s).Regards Bani Greyling Edited by moderator 20 May 2016 20:58:52(UTC)
| Reason: marked as solved (not a bug)
You must use the unit of measurement for temperature differences sergio
Thanks
I understand now what is happening: 300K + 10C -> 300K + 283.15K = 583.15K
Bani
Originally Posted by: banig 300K 10C - _______________________________________ Your understanding is correct: the unit of temperature is °K. Working with unit means consistant system, particularly true working trig functions. That freeware "Uconeer 2.4" from Katmar is most precious. Some smart decided the triple point of water that was 0 °C is now 0.01°C
