eval(,) ... Up to my understanding, at this point of using Smath for last 6 months it did 3 things spread over ~ 200 Smath work sheets: 1. It recasts the Cholesky solver as a function 2. In program running for discretised data it speeds up calculations [assuming it shortens the stack]. 3. In the attached work sheet, it "manages" a form of local definition, which Smath does not have Mathcad equivalent. For visitors familiar with Mathcad/Mathsoft, observe carefully the code translation. Y<-- Y+K*sin(2*pi*X) X<-- X+Y they both "encapsulate" the RHS as new variable from <-- local def'n. The Smath equivalent doing: eval(,) ... Welcome if you have more descriptive explanation. This work sheet about deterministic cahos is under construction. Jean Scrap Cahos 4150 Seed Rescued.sm (25kb) downloaded 45 time(s).
Thanks Davide,
I was just correct, in my own words from observation.
