For 3D only. Klein BottleEdited by user 10 August 2019 07:03:56(UTC)
on 13/11/2010(UTC), on 09/01/2013(UTC)
And how it works |
Calculation time: 7 min 30 sec sys(3*x-cos(y*z)-1/2=0;x^2-81*(y+0.1)^2+sin(z)+1.06=0;20*z+e^{-x*y}+1/3*(-3+10*π)=0;3;1)Edited by user 03 October 2012 19:01:41(UTC)
| Reason: Not specified File Attachment(s): uni attached the following image(s): |
If I load the file CreateMesh.sm, then both new builds (..68 and ..75) complain about plugin version required. However, the message requires a version that is already installed. The message can be ignored, than the file is loaded and executed without problems. File Attachment(s): mkraska attached the following image(s): |
I moved this function in the new plugin. You can delete the old Plot3D and use a new one - 3DPlotPlugin. In the future I'll change this function to work with 3D Plot. Open the document again, recalculate it and save it. The error should disappear. |
