SMath Studio Forum
Feature Requests
Split math expression into multiple lines
Joined: 03/02/2014(UTC) Posts: 67 Was thanked: 13 time(s) in 11 post(s)
Sometimes expressions get too long to stay within the margins. A way to split math expressions into multiple lines would be great for presentation of data in a clear way.
Originally Posted by: Ernesto Sometimes expressions get too long to stay within the margins. A way to split math expressions into multiple lines would be great for presentation of data in a clear way. Ernesto, That was a great feature of Mathcad. I do same as described by Ioan [decompose]. Eventually useful but useless in Smath, because the result from symbolic is in many ways not treatable: very long coefficients, all expressed in rational form. Jean
I would imagine Andrey could implement some sort of a wrap setting. It is all text after all.
On the other hand, if your equation does not fit in a page, are we trying to do too much in one equation? I did run into this issue myself and I ended up separating things
Originally Posted by: Alex.M I would imagine Andrey could implement some sort of a wrap setting. It is all text after all.
On the other hand, if your equation does not fit in a page, are we trying to do too much in one equation? I did run into this issue myself and I ended up separating things Easy in Mathcad, but might turn a blody mess. Much easier to split in components in Smath and lot more elegant. Jean
Jean, You shrank the font. This was not always easy in SMath (newer feature) and some old codgers yell and scream when the font sizes change in reports . As you said about Mathcad ... Originally Posted by: Jean Giraud That was a great feature of Mathcad... Jean I'm still holding on to Mathcad 15 for dear life (copied all license keys in triplicate) until I can transfer all or most of those sheets over to SMath. I really don't want to go through what you went through on your version of Mathcad rinks:
Originally Posted by: Andrey Ivashov Implemented (with some limitations) starting from SMath Studio 0.99.6619. If something similar to Mathcad 8 Pro <= 11 ... useless. It was demonstrated by Mathsoft, was never used by Collabs [> 125000 exchanges] Hyper delicate to use as you had to first set the ONE line equation then split by place holder/Enter. It could not be used for long symbolic derivatives whereas symbolic expansion couldn't be collected. I used it few times [typical Dirac symbolic integration]. The attached dates back two days ago, just refresh this morning. BTW Andrey, from recollection, I think YOU gave Dragilev Parametric. I have just made good use of it, delicate to make it profitable. Wait few days for Contour Utilities to be attached. Cheers Andrey, Jean Contour_8 Hypersurface.sm (52kb) downloaded 68 time(s).
Originally Posted by: Jean Giraud If something similar to Mathcad 8 Pro <= 11 ... useless. I didn't use this is Mathcad as well, but as I see from the Internet there was some special operator "+" which allowed to make a line break. If it is a true, then answer is - no, it is done by absolutely different way. Equation uses standard operators. Break is supported for "+", "-" and "*" when it is possible to break equation where user wants. In my point of view implemented approach is very convenient to use. This is implemented for cases when equation is larger then a paper size, so this is the only elegant way to show large equations. I'm still working on this feature, so I expect some improvements will be added soon. Edited by user 15 February 2018 20:35:03(UTC)
on 15/02/2018(UTC), on 16/02/2018(UTC)
Originally Posted by: Andrey Ivashov I didn't use this is Mathcad as well, but as I see from the Internet there was some special operator " " which allowed to make a line break. If it is a true, then answer is - no, it is done by absolutely different way. Equation uses standard operators. Break is supported for " ", "-" and "*" when it is possible to break equation where user wants. In my point of view implemented approach is very convenient to use. This is implemented for cases when equation is larger then a paper size, so this is the only elegant way to show large equations.
I'm still working on this feature, so I expect some improvements will be added soon. Up to Mathcad 11, '*' was not supported. I can see "split" useful if Smath can download from source a long single line formula. As well useful to export a long single line equation split for export. From within Smath ??? There was a Mathcad continued fraction converter to Wallis algorithm. This one does not work anymore here, my MCD 11 is only a back2back system. Courage Kamarad ! Maths Split_Collect.sm (140kb) downloaded 148 time(s).
WOW ... just WOW! Multiple realeases back to back AND one of my feature requests . Thank you! Originally Posted by: Andrey Ivashov Break is supported for "+", "-" and "*" when it is possible to break equation where user wants. In my point of view implemented approach is very convenient to use. This is implemented for cases when equation is larger then a paper size, so this is the only elegant way to show large equations. I'm still working on this feature, so I expect some improvements will be added soon. Sounds like this will automatically re-size? From the screenshot in the 6119 build, it looks like it's tied to the math region box (genius). Downloading BETA
Originally Posted by: ElSid WOW ... just WOW! OK, give an example of your WOWWOW Does not correlate my previous Useless [or almost useless]. please, attach your demo WOWWoW
Don't have to. Many times, the variable names are long to help define "what" it is. Instead of using "R sub one", I can now "print" equations where it's "R sub insfoam" + "R sub drywall" Makes it easier for the checker to follow. Trust me, I sometimes get lost in your sheets
1 user thanked ElSid for this useful post.
Joined: 28/11/2017(UTC) Posts: 20 Location: Pisa Was thanked: 2 time(s) in 2 post(s)
Hello everybody, sometimes the definition of a function requires multiple arguments and if you want them to be "self-explaining" (at least to a certain level) you have to use meaningful names for those. All these conditions might bring to a long line before you can type ":" and start with a definition line. At this point, the space on the paper for statements along the function definition might become a bit tight and the definition itself might be not printable(anything falling out of paper limit will be cutout in printing).
Any chance to have a split at ":=" in order to have the function definition beginning at the left margin of paper? Something like:
MyVeryLongFunction(OneNiceArgument, ASecondOne, ThisIsThird, Etc, Etc2, AnotherOne):= |A:= OneNiceArgument + Etc2 |B:= ThisIsThird * AnotherOne |Calculation:= ..... |ToBeContinued... |....
Thanks for any help on this subject
Marco
Hello Marco. Originally Posted by: MBernacca Any chance to have a split at ":=" in order to have the function definition beginning at the left margin of paper? Something like:
Yes, it is possible. After you have finished composing formula for definition just put the cursor before := and press Ctrl+Enter. This will produce something like Best regards.
Thanks to everybody for the prompt answers.
Marco
Originally Posted by: MBernacca Thanks to everybody for the prompt answers. Marco Visit this manageable example SS 6179 Take care Marco ... Jean Marco [Jean].sm (25kb) downloaded 95 time(s).
Very interesting Jean, thank you.
Marco
SMath Studio Forum
Feature Requests
