SMath Studio Forum
Questions
MathCAD to SMath batch conversion
Hi Kilele Sounds like you could read thoughts - This was/is the problem with FBSL... Couldnt find a portable version and tried allready some AutoIt and macrocreator/AutoHotkey. I'll have a look on your suggestion - Thanks a lot! Andreas
Originally Posted by: reselty Hi Kilele Sounds like you could read thoughts - This was/is the problem with FBSL... Couldnt find a portable version and tried allready some AutoIt and macrocreator/AutoHotkey. I'll have a look on your suggestion - Thanks a lot! Andreas Hi. You can compile .fbs to exe so you can run it on the final machine. Anyways, if you know autohotkey this script may be useful: http://www.donationcoder...oftware/Skrommel/#DoOver
Hi Kilele
I will test the DoOver way also, cause I did run a similar way with tinyTask, but there I couldn't define the speed (runs to fast) and edit the macro. Thanks a lot!
Joined: 06/03/2020(UTC) Posts: 3 Location: Paço de arcos
Hello guys!
I have a set of points x, y (speed and frequency) and I would like to take that moment of maximum speed, I have the corresponding frequency. Does anyone know to help me? Example:
vector, x=[1 2 3 ...1000] vextor, y=[100 300 400 ...100]
what point is in "y", "x" is max?
Originally Posted by: eltonsfg vector, x=[1 2 3 ...1000] vextor, y=[100 300 400 ...100]
what point is in "y", "x" is max? Your Y vector is incomplete. As it looks, it has different array dimension. Nothing can be constructed from what you give.
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 833 time(s) in 527 post(s)
Hi. This can be one solution. FindingAbsMaximun.sm (10kb) downloaded 20 time(s).or this other FindingAbsMaximunEpsilon.sm (8kb) downloaded 16 time(s).Best regards. Alvaro. Edited by user 19 November 2020 20:40:13(UTC)
SMath Studio Forum
Questions
