There is a bit more in the work sheet [Nsectors, inner radius]. More can be done... for instance: if the XY Lissajous would be a closed isoline around a mountain, it would easy to adapt this basic construction ... adjust the great circle, inner circle. You can add/size the inner circles. Jean 2D Radial Grid.sm (25kb) downloaded 39 time(s).
... ont his one: added noise on the inner circle. 2D Radial Grid.sm (43kb) downloaded 34 time(s).
1.sm (9kb) downloaded 23 time(s).
Hello Ber7,
Thanks for that one. I guess that's how they size cauliflower heads !
