Offline JJTTBB
#1 Posted : 02 February 2017 10:53:55(UTC)
JJTTBB
Greece
Hi... this is my first post here... Great work! Smath is fast and easy to learn.
There is a strange behaviour here... I try to calculate a simple cylinder section area. So Ab= pi*d^2/4
When I add the unit cm^2 , Smath adds 1/m2 * cm2 and no matter what I do, I can't change that... There is no variable in the calculation so no units
Another example
Anyone know a solution for that?
Thank you in advance.
Edited by user 02 February 2017 11:01:57(UTC)  | Reason: Not specified
#2 Posted : 02 February 2017 11:32:55(UTC)
Hello JJTTBB Offline ,
This is not a bug. SMath checks that the unit you assign in the rightmost placeholder is consistent with the units given in the left hand side.
If your intent is just to display a result, or you want to make dimensionless calculations and assign manually the dimensions on the results, right click on the region and select "Ignore units", then this feature will be ignored
Otherwise you have to assign the units in the LHS, and eventually adjust the result (results are given in base units)
other informations about units: wiki
Edited by user 03 February 2017 10:35:09(UTC)  | Reason: Not specified
#3 Posted : 02 February 2017 17:42:59(UTC)
Like this :
