Offline lcesero
#1 Posted : 19 June 2013 16:15:17(UTC)
lcesero
Hi Andrey,
I am getting a Novell ZENworks Application Virtualization Popup when running Smath
version 0.96 (build 4868). It is informing me that there are only 11 days left before the trial expires.
Louis
lcesero attached the following image(s):
#2 Posted : 19 June 2013 16:34:35(UTC)
Confirmed (SMath Studio 0.96.4868 portable)
regards,
Davide
Edited by user 19 June 2013 16:37:39(UTC)  | Reason: Not specified
#3 Posted : 19 June 2013 17:25:36(UTC)
I confirm that with 4868.
With 4875 and following builds, there is no such problem.
Offline kilele
#4 Posted : 19 June 2013 17:47:43(UTC)
kilele
Offline kilele
#5 Posted : 19 June 2013 19:10:07(UTC)
kilele
I tried "Cameyo" and "Enigma Virtual Box", without success possibly because I didn't played with configuration parameters. Both are freeware, I'd try the second one since it is a freeware product provided for a company which sells other type of programs.
Edited by user 19 June 2013 19:27:08(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#6 Posted : 19 June 2013 22:09:15(UTC)
Rank: Administration
Thank you for the info. It seems I have to finish using of Application Virtualization app for creating Portable versions (I just got a confirmation that finally ZENworks doesn't allow me to buy their product).
It was important because it includes .Net Framework 2.0 and allows users to use SMath Studio without requirement to install .Net Framework first.
Starting from Vista .Net Framework 2.0 is already preinstalled in the system, so I believe there is no need to support such kind of SMath Studio Portable anymore. Instead I will create a Portable packege without .Net included.
Regards.
Offline kilele
#7 Posted : 19 June 2013 22:30:18(UTC)
kilele
Please consider to make a portableapps.com compatible package
#8 Posted : 01 July 2013 15:20:59(UTC)
Expired Good
Only to mention it, the same problem appears in the 0.96.4883 portable.
regards
Davide
