SMath Studio Forum
Bugs & Problems
Novell ZENworks Application Virtualization Popup when running Smath
Hi Andrey, I am getting a Novell ZENworks Application Virtualization Popup when running Smath version 0.96 (build 4868). It is informing me that there are only 11 days left before the trial expires. Regards, Louis lcesero attached the following image(s):
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
Confirmed (SMath Studio 0.96.4868 portable) regards, Davide Edited by user 19 June 2013 16:37:39(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1125 time(s) in 722 post(s)
I confirm that with 4868.
With 4875 and following builds, there is no such problem. |
I tried "Cameyo" and "Enigma Virtual Box", without success possibly because I didn't played with configuration parameters. Both are freeware, I'd try the second one since it is a freeware product provided for a company which sells other type of programs. Edited by user 19 June 2013 19:27:08(UTC)
Thank you for the info. It seems I have to finish using of Application Virtualization app for creating Portable versions (I just got a confirmation that finally ZENworks doesn't allow me to buy their product). It was important because it includes .Net Framework 2.0 and allows users to use SMath Studio without requirement to install .Net Framework first.
Starting from Vista .Net Framework 2.0 is already preinstalled in the system, so I believe there is no need to support such kind of SMath Studio Portable anymore. Instead I will create a Portable packege without .Net included.
Regards.
Please consider to make a portableapps.com compatible package
Expired Only to mention it, the same problem appears in the 0.96.4883 portable. regards Davide Davide Carpi attached the following image(s): |
SMath Studio Forum
Bugs & Problems
