I've just tried Martin's distro with the full plugin and got the same error as you, everything is broken (all samples in docs' plugin) with the same ionic.zip error. Curiously enough, I think that this didn't happened in Linux (it worked only export correctly) but I want to do more tests in Linux. edit: yes i had a plugin disabled when starting smath but dont know which one yet. i'll edit this post later on. Edited by user 03 May 2013 00:34:00(UTC)
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
Originally Posted by: kilele I've just tried Martin's distro with the full plugin and got the same error as you, everything is broken (all samples in docs' plugin) with the same ionic.zip error. Curiously enough, I think that this didn't happened in Linux (it worked only export correctly) but I want to do more tests in Linux.
edit: yes i had a plugin disabled when starting smath but dont know which one yet. i'll edit this post later on. I tried it as well in Xubuntu using Martins' version. No errors about Ionic.zip. Save as ODT is working, but it seems that only the text can be saved. I did not manage to save formulas and plots. Regards, Radovan |
Joined: 15/04/2012(UTC) Posts: 1,987 Was thanked: 1124 time(s) in 721 post(s)
I had a closer look at the DataExchange plugin under 0.96. For now, I see the XeTeX and csv export working fine, others still have to be checked, but there are problems in the example files. Unfortunately, I am not keeping pace with the flood of updates in the forum, thus it will take a while until distro and handbook will have settled and updated. Currently, I am just focussing on bug reports and test feedback. |
Hello Davide, I do not know why some of your post have to be approved sometimes Originally Posted by: w3b5urf3r_reloaded Sorry, I forgot that ClosedXML thing . Martin mentioned it few times. Regards, Radovan |
Please download this file to see my test on SolusOS Linux, Repository: Debian Stable; Desktop manager: Gnome2.3, btw SMath is very responsive in this manager. This file contains the plugin docs and some screenshots showing errors while running the program. An this is the plugin tested in Zorin(ubuntu) http://www.mediafire.com/?p4ehqsr6pgs2vwlEdited by user 03 May 2013 11:28:34(UTC)
1 user thanked kilele for this useful post.
Originally Posted by: w3b5urf3r_reloaded Just to try to conclude something about this. It seems to me that the same (or similar) problem comes with v0.96 and this plugin and the mcadEFI plugin by uni . As I understood this well, there will be fixed on the next SMath release. Until then these plugins are "off" the use, or to continue using them in 0.95. I hope I was right about it. By the way, the activity on the Forum increased quite a lot, almost hard to follow . I am not complaining, just contrary Regards, Radovan |
Originally Posted by: omorr Just to try to conclude something about this. It seems to me that the same (or similar) problem comes with v0.96 and this plugin and the mcadEFI plugin by uni . As I understood this well, there will be fixed on the next SMath release. Until then these plugins are "off" the use, or to continue using them in 0.95. I hope I was right about it. By the way, the activity on the Forum increased quite a lot, almost hard to follow . I am not complaining, just contrary Regards, Radovan If you really need mcadefi plugin you can do this (Andrey asked not tell about it nobody ):
Put (move) mcaduser.dll near SMathStudio_Desktop.exe
Edited by user 03 May 2013 21:58:09(UTC)
Russia ☠forever Viacheslav N. Mezentsev |
Originally Posted by: uni If you really need mcadefi plugin you can do this (Andrey asked not tell about it nobody ): Thank you uni, this workaround solve all the issues BTW this make dirty the SMath's installation folder, so it's really better to not use it if not strictly required. best regards, w3b5urf3r |
Originally Posted by: w3b5urf3r_reloaded Originally Posted by: uni If you really need mcadefi plugin you can do this (Andrey asked not tell about it nobody ): Thank you uni, this workaround solve all the issues BTW this make dirty the SMath's installation folder, so it's really better to not use it if not strictly required. It does not work for me, or I did not figure out . Never mind, I hope that will work for most of the users Regards, Radovan |
PLUGIN UPDATED- change of requirements: SMath Studio 0.96.4875 (07 May 2012) - relative path improvements; - ODS export vs symbolic optimization fix; - patch on ODT embedded images for Linux users; - SMath Viewer compatible. best regards, w3b5urf3r Edited by user 08 May 2013 02:45:05(UTC)
Joined: 01/09/2011(UTC) Posts: 11 Location: Cyberjaya, Malaysia Was thanked: 2 time(s) in 1 post(s)
Thanks. Seems to work fine now.
Steve
Originally Posted by: steveswin Thanks. Seems to work fine now.
Steve You're welcome |
PLUGIN UPDATED- XLSX features moved away (see Xlsx Import/Export plugin ) - plugin added to the Gallery (Latest Nigthly build) - Added Guid (after installing the plugin, a message should appear opening old files, just skip it and save again the file) best regards, Davide Edited by user 10 June 2013 11:44:23(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
4 users thanked Davide Carpi for this useful post.
on 10/06/2013(UTC), on 10/06/2013(UTC), on 10/06/2013(UTC), on 10/06/2013(UTC)
UPDATED (Gallery only)- fixed: SMath Studio 0.96.4909 (10 June 2013) vs XeLaTeX saves Edited by user 17 September 2013 20:13:00(UTC)
when the program starts, the following message appears operating system Win 7 smath versione 096 4868 net framework 4.5.1 Edited by user 30 December 2013 14:58:41(UTC)
| Reason: Not specified paolo1963 attached the following image(s):
Hi Paolo, I can't reproduce your issue (win7 x64 - SMath 0.96.4909) Are you sure that this plugin cause the issue? copy and paste the red string ( %APPDATA%\smath\extensions\plugins ) in your windows start menu, press the return key and then delete the plugin folder ( 5dce7298-9e5f-4120-9a2e-49b16daa02a3) then try to start SMath again. Davide Edited by user 30 December 2013 17:47:00(UTC)
I uninstalled the version of SMath 096 4868 and I installed version 096 4909 now the program starts. Save in *. odt work, while saving in *. tex from the following error message: paolo1963 attached the following image(s):
Really strange, I can't reproduce this issue The problem is related to some worksheet (empty file, with figures, with text, with math), some machine, or is general? Have you the same issues with the unofficial portable version? You could try to share here your system informations ( Development Tools plugin > System informations > save as... > attach here the file) Davide Carpi attached the following image(s): |
