#1 Posted : 12 February 2014 20:25:25(UTC)
This happens when the clipboard contains strings with spaces (Win7 x64 / SMath Studio 0.97)
P.S. this not happens using the nightly build 0.96.4909
Quote:
Le informazioni su come richiamare il debug JIT (Just-In-Time) anziché questa finestra
sono riportate in fondo al messaggio.
************** Testo dell'eccezione **************
System.NullReferenceException: object reference not set to an instance of an object.
in SMath.Control.Worksheet.(String )
in SMath.Control.Worksheet.Insert(String value)
in SMath.Control.WorksheetControl.OnKeyDown(KeyEventArgs e)
in System.Windows.Forms.Control.ProcessKeyEventArgs(Message& m)
in System.Windows.Forms.Control.WmKeyChar(Message& m)
in System.Windows.Forms.Control.WndProc(Message& m)
in System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
in System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
best regards,
Davide
Edited by user 12 February 2014 23:04:23(UTC)  | Reason: Not specified
#2 Posted : 12 February 2014 23:05:45(UTC)
update: I notice the same issue even when I copy and paste a string with spaces from a text area to the canvas (so probably the HTML data is not the cause)
Offline Andrey Ivashov
#3 Posted : 13 February 2014 00:10:56(UTC)
Rank: Administration
Cannot reproduce on latest 0.97 (tried the same text you shown on screenshot and some others).
May it be caused by some plug-in installed? If you will find it out I hope to find a way to prevent such kind of problems in future.
on 13/02/2014(UTC)
Online mkraska
#4 Posted : 13 February 2014 00:32:08(UTC)
I can confirm that strange things happen:
1. Open installed 0.97 with nearly all plugins enabled.
2. paste "ddd " to the canvas - a hyperlink region with that string appears
3. Switch off Hyperlink Region in the extension manager
4. paste "ddd " again - a snapshot region appears
5. Disable snapshot region as well
6. Again pasting "ddd " - a crash happens with the following details:
I can repeat that.
What I cannot repeat: sometimes pasting creates a conditionally formatted label, but I did not yet recognize the pattern how to invoke that.
on 13/02/2014(UTC)
#5 Posted : 13 February 2014 01:05:16(UTC)
Thank you Martin and Andrey,
I've removed all the plugins and I can reproduce what Martin said...
The crash is caused by a third plugin, DevelopmentTools Huh .... the behavior of the Hyperlink and Snapshot regions is incredible... I'll investigate a little bit more Shok
Edited by user 13 February 2014 01:07:16(UTC)  | Reason: Not specified
#6 Posted : 13 February 2014 01:25:13(UTC)
OK my diagnosis:
- DevelopmentTools:
This code cause the crash (here the plugin doesn't override the Paste(IClipboardManager clipboard) function)
Code:
public string[] SupportedClipboardFormats
	get { return new string[] { DataFormats.UnicodeText }; }
This solve the problem (at least for the users):
Code:
	get { return new string[0]; }
Hyperlink & Snapshot Regions:
- SMath triggers the public override bool Paste(IClipboardManager clipboard) of any available plugin, even if there aren't regions on the canvas (but this should happens only if a region exists and is focused)
Edited by user 13 February 2014 01:26:46(UTC)  | Reason: Not specified
on 13/02/2014(UTC)
#7 Posted : 13 February 2014 01:39:15(UTC)
Thank you! I will implement fix asap.
on 13/02/2014(UTC)
#8 Posted : 13 February 2014 03:18:35(UTC)
Thank you very much Andrey OK
I don't have noticed the bug in the front-end, but I've fixed the code as for the Development tools and I've pushed in the EM an update Secret
