Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,650 Location: Italy Was thanked: 1338 time(s) in 878 post(s)
Originally Posted by: ioan92 "The variables should be assigned to their desired values only after the function is defined." sic! That's true only if you don't use line() to define your function; in this case to avoid the behavior you must set the optimization of the function definition to "numeric". Edited by user 09 August 2013 01:07:13(UTC)
| Reason: Not specified Davide Carpi attached the following image(s): |
1 user thanked kilele for this useful post.
Originally Posted by: mkraska the link does not work because of the trailing comma, anyway this can viewed as vote buying, paypal me hard and I'll vote your bugs
So what? Keep in mind that this was a hint on that the topic has been shifted to the bug tracking system. Thanks for the hint with the comma. |
Thank you! This issue is pretty critical. Will handle it asap. All bugs I will manage using http://smath.info/bts/, so Features/Bugs subforums is redundant now.
