Offline Tinu
#1 Posted : 27 August 2014 17:39:07(UTC)
Tinu
Rank: Member
Switzerland
Was thanked: 14 time(s) in 12 post(s)
Tipp: Another way of using SMathStudio with Linux
after quite some trial and error I finally managed to get SMathStudio running under Wine.Clap
This seems to improve the appearance and some other inconveniences of using SMathStudio with mono are overcome.
File Attachment(s):
Wine_Installation.sm (37kb) downloaded 116 time(s).
Tinu attached the following image(s):
thanks 2 users thanked Tinu for this useful post.
on 27/08/2014(UTC),  on 27/08/2014(UTC)
#2 Posted : 27 August 2014 21:43:30(UTC)
Glad to hear that the portable distribution works under wine.
As to Maxima I can just guess: Might the problem be related to the socket connection? Can you run wxMaxima under wine? This has to be tested with the original windows installer of Maxima, because our messing around with the maxima.bat file corrupted the ability of wxMaxima (under Maxima-5.33.0.1\wxMaxima\wxmaxima.exe) to connect to Maxima. wxMaxima and the Maxima plugin use similar connections to the back end.
Offline omorr
#3 Posted : 27 August 2014 23:06:41(UTC)
omorr
Rank: Administration
Serbia
Could you give us the detailed instruction (step by step) of how did you do this?
Offline Tinu
#4 Posted : 29 August 2014 15:25:39(UTC)
Tinu
Rank: Member
Switzerland
I installed wxMaxima (windows installer) and get the error Not connected to Maxima.
According to an internet search this seems to happen quite often. I was not able to find any plausible explanation or remedy for this situation. Some people blame firewalls or security settings, of which I have neither on my Linux. Moving wxMaxima to another directory does unlock the settings menu (which doesn't work when wxMaxima resides in a subdirectory of Maxima) und thus enables one to set the path to maxima.bat manually, but this didn't work either.
Plain Maxima itself does work however.
The installation under Wine overcomes some of the well known drawbacks of the standard mono-version on Linux viz. no embedded pictures if file was created with windows-version (especially annoying with the interactive handbook), problems with certain plug ins, poorer visual appearance, garbled text regions, tab-key not working etc.
Unfortunately, there are still some further (minor) problems.
I get an impressive list of errors before SMath starts (successfully!) if I use the console to start it. (see attachment).
Being quite new to Linux, I am a bit at a loss.
My guess is that maybe I am still missing some vital dll?
I do hope some Linux guru can help further.
In my case the start command is:
env WINEPREFIX="/home/tinu/.local/share/wineprefixes/dotnet3" wine C:\\2014\ 08\ 24\ SMath\ and\ Maxima\\SMathStudio_Desktop.exe
I have tried my best Good -> see: second attachment
Martin
File Attachment(s):
SMath_errorlog.pdf (28kb) downloaded 67 time(s).
Smath_with_Wine.pdf (611kb) downloaded 174 time(s).
thanks 1 user thanked Tinu for this useful post.
on 30/08/2014(UTC)
#5 Posted : 29 August 2014 16:35:49(UTC)
If I use the Maxima-Installation in the portable SMath-Distribution under Windows, then I get the same error. We did some changes in maxima.bat in order to work in a portable way with SMath. This may have corrupted the call from wxMaxima. The real connection test would be to install the original windows package for Maxima and try wxmaxima there.
I attach the origina maxima.bat. You need sufficient rights in order to create the temp directories and write to them.
File Attachment(s):
maxima.zip (2kb) downloaded 72 time(s).
Offline Tinu
#6 Posted : 04 January 2015 20:43:47(UTC)
Tinu
Rank: Member
Switzerland
SMathStudio and Maxima with Wine
Clap Latest inofficial portable version dated 16.11.2014 with Maxima 5.34.1 works on my system!
I have no idea whether this is due to changes in the plugin or in Maxima itself.
I have updated the installation instructions (see attachment).
File Attachment(s):
Smath_with_Wine_2.pdf (630kb) downloaded 216 time(s).
on 06/01/2015(UTC)
Offline carlton
#7 Posted : 24 April 2015 02:11:07(UTC)
carlton
This stops half way through saying it does not support 64bit systems (Ubuntu 14.10 64bit on HP XW6200)
