Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1331 time(s) in 876 post(s)
UPDATED- SMath Studio 0.96.5146 or later required- [EDIT: February 10, 2014] dll direct download removed (SMath without Extensions Manager is no longer supported) best regards, Davide Edited by user 10 February 2014 23:10:09(UTC)
| Reason: dll direct download removed |
I runned in to an issue with the exportData.ODS and exportData.XLSX function. If the *.sm file is compiled to *.exe (with save as.. name.exe), the newly created *.exe file will not create ODS or XLSX files. Thanks. Edited by user 15 December 2014 14:18:36(UTC)
This is because Viewer's Store.FileName property contains the file name of the parent SMath worksheet (I suppose is by design). I've tried to implement a workaround (uploaded in the EM). Should works also on unix systems but I'm not sure. Test it deeply and report any issue. If it works I'll do the same for the XLSX plugin. Best regards, Davide Edited by user 16 December 2014 12:21:48(UTC)
Hello! I've tested the update and now the ODS file is created. If the exportODS function is not hidden in an area then it is working perfectly. If you hide the exportODS function in an area then the exported (the outputfile) ODSfile won't be refreshed if you make changes in the *.exe file (ex. ComboBox). Thanks! Szabi
Using collapsed area a file is created when you open the executable, this it means that the function is evaluated; the content of the collapsed region is no more evaluated when you change the combobox item. I guess the issue is in the RequestEvaluation triggered from the combobox in the SMathViewer vs the collapsed areas, that is not in my hands (API stuff). BUG opened: SV-1254Edited by user 16 December 2014 21:28:13(UTC)
Hello!
First of all - thank you for the plugin - I was playing with it for a while and it seems to import data from ODS very well.
Now, for the export function, is there a way to "modify" a single cell in existing ODS file? What I am trying to achieve is to use spreadsheet as a large data processor (it is quite good at it), while I would like to use Smath to feed variables into the spreadsheet and to get output from it.
Many thanks
Hello oxel007! I guess this is not possible, at least without a third-party library to handle correctly the existing data. If you need this, the simplest way is to reference the output spreadsheet of SMath in you spreadsheet; you have to open both the files the first time to link the cells, then your data processor will load automatically the data from the first even without opening it again (attached an example both for ODS and XLSX spreadsheets - links are shown as absolute but are relative, so if you keep the structure of the folders you can move them where do you want) |
Davide, I have spent some time trying to develop a complete solution that would export data from smath to xlsx or ods, recalculate the spreadsheet using new values, and import the updated output back into smath. Unfortunately I am stuck. 1. Excel plugin does not seem to import value that is obtained by a formula (multiply one cell by another) 2. Neither XLSX nor ODS plugins update the spreadsheet using external links at the time of import. Please see attached. If we successfully tackle this I believe it will be used by a few people - Smath and Excel are powerful tools and each has strengths and weaknesses. Best Regards
Thank you for sharing an example. For the 1st point I think I've found a solution, an updated XLSX Import/Export plugin is available in the EM; For the 2nd point, both the plugins handles just data from/to the files. Data preprocessed by SMath is written in the file or data preprocessed and saved by some kind of excel program is read from the file. This means that to get updated results from the spreadsheet you have to open it, save the updated file, and then refresh the SMath worksheet (or split the SMath worksheet in 2 worksheets: open the first worksheet, open & update & save the spreadsheet, open the second worksheet) To accomplish your task in just one step, another plugin with functions to trigger the third-party application in background is needed (something like a MS Excel COM plugin / LibreOffice Calc COM plugin / or a plugin that handles in background any other program you have on your system) Edited by user 07 March 2015 16:25:40(UTC)
That makes sense; possibly pyUNO can be used to update ODS file in background. However given my non-existing programming skills it is highly unlikely I will be able to incorporate it myself - I will just stick to reopening files manually. Thank you for your help
You're welcome... When it will be possible I'll explore this thing (I've seen a couple of interesting posts for both the APIs of excel and libreoffice) |
Is there any particular way that I may assist you with this? If you point me in the right direction I could research how this feature may be implemented (xlsx files) - I am not a programmer but can attempt my best to piece pieces together.
A little bit background on why I think that is important:
Quite often we, number crunchers, have previously created spreadsheets (in Excel) to do specific tasks. Those spreadsheets have been triple checked by ourselves and others to contain no bugs. At times it is enforced that we use specific spreadsheets for specific calculations.
It would be immensely useful to use SMath Studio to input data in a given spreadsheet and to record corresponding output. In fact it will effectively make use of a spreadsheet as a monstrous data crunching formula that was previously verified to work by others. You feed in data, record output for different variable sets and present them in a readable format of SMath Workbook.
PLUGIN UPDATED SMath Studio 0.97.5737- importData.ODS(): can access files opened by other processes (only saved data);
- importData.ODS(): sheet name no more case-sensitive;
- importData.ODS(3): range of cells accepted as 3rd argument;
Edited by user 20 January 2016 19:36:42(UTC)
on 20/01/2016(UTC), on 21/01/2016(UTC)
Originally Posted by: Alex.M It would be immensely useful to use SMath Studio to input data in a given spreadsheet and to record corresponding output. In fact it will effectively make use of a spreadsheet as a monstrous data crunching formula that was previously verified to work by others. You feed in data, record output for different variable sets and present them in a readable format of SMath Workbook. _______________________ As soon as I was given Mathcad 11 by Mathsoft, Mathcad 11 came with Excel read/write spread sheet. In the remainng of the > 120000 Collaboratory exchange [which I read all] not a single *.XLS [now *.ODS] were exchanged. But lot of data were referenced in technical/scientific web sites. The universal data exchange is *.dat. If you can't paste directly in Mathcad because you want to get rid of comments ... just transit via NotePad and clean, then copy/paste back in Mathcad data table. That would be useful in Smath, at least to read *.dat. Smath is a CAS, Excel is just a spread sheet. A very minimal amount of Smath work could be exchanged, especially wrt the miserable way many results are obtained from Smath. In 15 years, I have not even done 2+3 in Excel. I guess it mothballed itself. If you like so much "Spread Sheet", OriginLab is quite a tool and superb plotter as well as doing lot of curve fitting. Jean
Originally Posted by: Jean Giraud In 15 years, I have not even done 2+3 in Excel. Jean, it might not be true for you in particular, but for many in my field it is a requirement to re-use existing spreadsheets. Additionally it is hard to beat excel when you need to mass edit your formulas to correct an error or add a feature (in fact find/replace in not even an option in SMath). I would hate to make a choice between CAS and spreadsheets. Both are great; in their own ways. Anyway, it has been quite a while since the post you are looking at - I have addressed my own request by creating plugin excel_IO, which I find very useful. Cheers, Alex M.
My friend: you have good arguments. I developped my gorgeous "Thiele Continued Fraction" in Excel Millenium. In 2005, switched to XP Home, result: zap all my previous Excel. Lot more than Thiele. Nothing else was scrapped, only Excel. FindReplace is more delicate than it looks: exact value, range ... This work sheet works for me, why not for you ? Jean Utilities Matrix Find_Replace.sm (20kb) downloaded 73 time(s).
on 23/01/2016(UTC), on 23/01/2016(UTC)
Beautiful function your FindReplace function Jean I think he is looking for a general search & replace, both for math and text and able to acting on the whole worksheet. I'm working on something, search works pretty fine with small limitations Edited by user 23 January 2016 14:58:01(UTC)
3 users thanked Davide Carpi for this useful post.
on 23/01/2016(UTC), on 23/01/2016(UTC), on 23/01/2016(UTC)
Hello Davide, I have problems with the export XeLaTeX. First it is highlighted exception Proceeding is inhibited the choice of options Proceeding is nevertheless produced a tex file You must still add the following line in the markup to fill in XeLaTeX \newcommand{\defeq}{\coloneq} % SMath 'define equal' symbol PS some addition function is not implemented, however, the qualitative result of the prints obtained is much higher than that of normal export pdf. I would hate a little if this project was abandoned sergio
