#1 Posted : 20 February 2016 03:22:11(UTC)
Hello Ioan,
I confirm the different behavior in the 2 versions. In the latest, there is a minus sign change in the interpolated points of xθs; you should investigate the math to see if it was wrong before and you didn't noticed because the minus bug in augment/submatrix or if the math is correct and this is a new bug about the signs.
Removing all the minus from stack/augment in θtd, θθx, θv I get the correct interpolation (but in this moment I'm a little bit tired and I'm not sure if I have broken the math or some sign convention).
Solution testCBSmath.sm (1,293kb) downloaded 15 time(s).
Edited by user 23 April 2016 12:11:44(UTC)  | Reason: Not specified
on 20/02/2016(UTC)
#2 Posted : 20 February 2016 07:12:34(UTC)
Salut Ioan,
Big stuff ! The 2nd plot turns red "Arrays dimension do not match"
The sign errors look coming from your Interp that is incompletely defined.
It does same as the Smath built-in "linterp(X,Y, point)"
on 20/02/2016(UTC)
#3 Posted : 20 February 2016 18:50:18(UTC)
Thank you "Gurus" ... no more red in 5346.
As it looks, it solved earlier version(s)
Snow job today ...
Québec is a two seasons country: Winter & July .
The largest snow flake [Colorado] 20 cm diameter !!!
Quite a pancake, just add maple sirup.
Cheers Collabs, Jean
on 20/02/2016(UTC)
Offline Andrey Ivashov
#4 Posted : 20 February 2016 19:22:45(UTC)
Rank: Administration
Ioan, thank you for your research.
As I understood you see differences in calculations between two SMath Studio versions just because of one of the latest changes (in 5890):
Originally Posted by: Andrey Ivashov Go to Quoted Post
SS-2292: Symbolic calculation error of augment(...) and submatrix(...) functions fixed (happened sometimes when matrices in arguments were negative);
So, I expect now your calculations is absolutely correct.
Edited by user 20 February 2016 19:24:19(UTC)  | Reason: Not specified
on 20/02/2016(UTC),  on 20/02/2016(UTC)
