SMath Studio Forum
Bugs & Problems
Different results using SMath 097.5737 and 097.5890
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,648 Location: Italy Was thanked: 1329 time(s) in 875 post(s)
Hello Ioan, I confirm the different behavior in the 2 versions. In the latest, there is a minus sign change in the interpolated points of xθs; you should investigate the math to see if it was wrong before and you didn't noticed because the minus bug in augment/submatrix or if the math is correct and this is a new bug about the signs. Removing all the minus from stack/augment in θtd, θθx, θv I get the correct interpolation (but in this moment I'm a little bit tired and I'm not sure if I have broken the math or some sign convention). Solution testCBSmath.sm (1,293kb) downloaded 14 time(s).Edited by user 23 April 2016 12:11:44(UTC)
Salut Ioan, Big stuff ! The 2nd plot turns red "Arrays dimension do not match" The sign errors look coming from your Interp that is incompletely defined. It does same as the Smath built-in "linterp(X,Y, point)"
Thank you "Gurus" ... no more red in 5346. As it looks, it solved earlier version(s)
Snow job today ... Québec is a two seasons country: Winter & July . The largest snow flake [Colorado] 20 cm diameter !!! Quite a pancake, just add maple sirup.
Cheers Collabs, Jean
Ioan, thank you for your research. As I understood you see differences in calculations between two SMath Studio versions just because of one of the latest changes (in 5890): Originally Posted by: Andrey Ivashov SS-2292: Symbolic calculation error of augment(...) and submatrix(...) functions fixed (happened sometimes when matrices in arguments were negative); So, I expect now your calculations is absolutely correct. Best regards. Edited by user 20 February 2016 19:24:19(UTC)
on 20/02/2016(UTC), on 20/02/2016(UTC)
SMath Studio Forum
Bugs & Problems
