14 Pages«<7891011>»
#161 Posted : 09 March 2014 21:39:32(UTC)
Originally Posted by: ioan92 Go to Quoted Post
password for the Nonlinear Solvers plugin?
http://en.smath.info/for...lgorithms.aspx#post10204
on 09/03/2014(UTC),  on 10/03/2014(UTC)
#162 Posted : 10 March 2014 13:40:36(UTC)
plugin's password added in the first post.
Best regards,
Davide
#163 Posted : 31 August 2014 21:05:55(UTC)
Originally Posted by: w3b5urf3r_reloaded Go to Quoted Post
Thank you Martin,
you are right, I'll try to fix it...
This seems to be a matter of the perturbation size.
File Attachment(s):
Jacobian.CD.sm (15kb) downloaded 52 time(s).
on 01/09/2014(UTC)
#164 Posted : 03 March 2016 21:03:51(UTC)
PLUGIN UPDATED SMath Studio 0.97.5346, SMath Studio 0.97.5737, SMath Studio 0.98
- Unknowns() now can be used inside functions (will returns 0 if no unknowns are found, instead of an error message);
- version numbering switched to 1.1.* to made easier to publish updates for different SS versions (next milestone: 1.2.*);
- password no longer required for those SS versions;
Edited by user 03 March 2016 21:36:42(UTC)  | Reason: Not specified
on 03/03/2016(UTC),  on 03/03/2016(UTC)
Offline Alex M.
#165 Posted : 07 April 2016 21:45:39(UTC)
Alex M.
Hello Davide,
I am somewhat confused why FindRoot() cannot solve this equation. Am I doing something incorrectly?
It works just fine for some other equations..
Thanks!
FindRootCannotSolve.sm (5kb) downloaded 41 time(s).
Edited by user 07 April 2016 21:47:21(UTC)  | Reason: Not specified
#166 Posted : 07 April 2016 22:10:06(UTC)
Hello Alex,
I cannot reproduce... do you have Maxima or some other plugin that may cause the issue?
Offline omorr
#167 Posted : 07 April 2016 22:18:09(UTC)
omorr
Rank: Administration
Serbia
It works for me. The same was mentioned some time ago here. It seems that some plugin is making trouble. I do not know which one.
Offline Alex M.
#168 Posted : 07 April 2016 23:03:40(UTC)
Alex M.
Omorr, Davide:
- Uninstalling Maxima plugin did nothing
- Clean install of stable 0.98 SMath Studio solved the issue. Now I just need to find what other plugin is wreaking havoc there..
Thank you
thanks 1 user thanked Alex M. for this useful post.
on 08/04/2016(UTC)
#169 Posted : 08 April 2016 04:57:46(UTC)
Maths are unitless, therefore plot first the generatrix
to discover the function has no root(s). If you fabricate
with a unit system, you will have no plot. That's what I
call "invisible project"
#170 Posted : 08 April 2016 05:01:10(UTC)
... the other point is that Smathh is too granular to
reveal the Gaussian part of the function.
Offline mikekaganski
#171 Posted : 08 April 2016 05:16:56(UTC)
mikekaganski
You make a wrong point here. You prefer to avoid using units in your sheets, and that's your right; but declaring that units are inappropriate (as you do now and again) is spreading FUD. Using units is a great feature of SMath (that is optional, so that you may choose to work as you like), but your unawareness of ways to take advantage from using units while keeping ability to, e.g., plotting, doesn't mean that it's good to state such bold claims (insted, you could simply create a new thread in "Questions" and ask others how to plot while using units).
Second, the function itself doesn't have roots, but original poster looked not for equation f(x)=0, but for f(x)=n, which is f(x)-n=0.
Third, you mistakingly put square for pi (it was meant for seconds, not for pi - if you used units, you would katch this, because the result would arrive in s*Pa).
Edited by user 08 April 2016 05:52:59(UTC)  | Reason: Not specified
Best regards,
Mike Kaganski
#172 Posted : 08 April 2016 05:54:08(UTC)
... maybe that's what you had 4800481^2 instead of
4800481 m^2... just different scale plot. Whatever,
the negative branch has two symmetric complex roots.
#173 Posted : 08 April 2016 06:13:20(UTC)
Maths are unitless, end of it.
It would be fine in Smath if units would be decoration
but it's not in Smath 5346. From what Andery replied to
me, new versions have decoration style like Mathcad 11.
What do you put as units in Fourier, Laplace ...
In the Legendre Quadraature [Reconciliation] just posted
What's the unit of the cumulative integral ?
Answer: user "UnitGraphic".
So, we live it here.
Cheers, Jean
#174 Posted : 08 April 2016 06:30:31(UTC)
mikekaganski
Please, don't multiply the offtopic here.
http://twt.mpei.ac.ru/oc...MC_MP/Unit_MC_MP_eng.htm
Best regards,
Mike Kaganski
Offline ElSid
#175 Posted : 08 April 2016 23:32:00(UTC)
ElSid
United States
Jean,
You tried really hard on the Mathcad forums to preach the same thing and was a huge detractor to your work ... which is quality collaboration and maths.
Now, your preaching about graphing ... that is something worth "harping" on!
#176 Posted : 09 April 2016 07:31:42(UTC)
Quite right, the debate lasted for a while in the Mathsoft Collaboratory.
I defeated my detractors twice and for ever in this Colaboratory:
1. I put units in the Reynolds number [unitless] but got result that
none could decipher, even Mathsoft.
2. Doing some Plank physics, same thing: not decipherable.
The best was that no collab [to my recollection] posted advanced problems
with units. Use units in your profit but make sure you check unitless.
Units system is for personal use at arithmetic maths level.
Cheers, Jean
#177 Posted : 09 September 2016 22:41:23(UTC)
The Taylor() function throws the error message "Specify variable"
How am I expected to do this?
#178 Posted : 09 September 2016 23:39:24(UTC)
As it looks Martin, "Taylor" is by default.
#179 Posted : 10 September 2016 00:54:26(UTC)
You assigned a wrong value for the 2nd argument, "2:variable".
#180 Posted : 10 September 2016 02:15:05(UTC)
Hm, don't understand. For univariate expressions, the second argument is the development point.
For multivariate expressions, I would expect that I have to specify the independent variable and the development point.
In Maxima (not working in newer versions of SMath) it looks like this:
With your Taylor, I have this:
Sorry, I don't understand the result.
Analysis.sm (29kb) downloaded 40 time(s).
Guest (2)
14 Pages«<7891011>»
