Offline RamonTavarez
#1 Posted : 13 March 2016 17:45:32(UTC)
RamonTavarez
Rank: Member
Was thanked: 2 time(s) in 1 post(s)
Since Smath Studio 0.98.5908 I can't install on my computer. :'(
The instalation stops and warn me:
I can see that it has to be with my system, not with Smat Studio , because my system don't have the referred KEY.
Can someone help me with this issue?
Edited by moderator 23 April 2016 12:09:28(UTC)  | Reason: marked as solved
#2 Posted : 13 March 2016 20:07:36(UTC)
RamonTavarez
Rank: Member
@ ioan92:
I uninstalled the software and cleaned the registry, but the result was the same before trying to install the new version.
Any idea?
#3 Posted : 14 March 2016 02:13:04(UTC)
Originally Posted by: ioan92 Go to Quoted Post
Check if you have installed the .NET Framework 3.5
If not, look for the help from Microsoft to install it.
Probably barely useful, if he uninstalled a previous SS version the framework should be available. Huh
Causes and solutions related to that registry key: Microsoft Community
Edited by user 14 March 2016 02:20:34(UTC)  | Reason: Not specified
on 14/03/2016(UTC)
#4 Posted : 16 March 2016 21:37:53(UTC)
RamonTavarez
Rank: Member
.NetFramework 3.5 is ok.
Special detail:
I can install without trouble until SS v0.97.5737, but can´t install the newest version. SS v0.97.5737 doesn´t not look for or work on HK_LOCAL_MACHINE32\software\ ....
Why newer versions ask for these KEY?
Offline Andrey Ivashov
#5 Posted : 17 March 2016 00:08:32(UTC)
Rank: Administration
I'm not sure why does it happen. I just updated a tool which creates MSI packages and prepared new installer for you to test: http://smath.info/file/hSHdD
Please let me know if it do help or not.
Thanks in advance!
#6 Posted : 17 March 2016 02:25:11(UTC)
Same thing Smath 5346 XP SP3: Smath does not exist in the Registry.
A faint vxMax that does not necesarily implies Maxima. That's
probably why Maxima does finds itself in the jungle, except for
Maxima stuff that comes from the Insert menu f(x).
Offline mikekaganski
#7 Posted : 17 March 2016 03:04:53(UTC)
mikekaganski
Can you check the permissions of HKEY_LOCAL_MACHINE\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\SharedDLLs?
This is the place where your HKEY_LOCAL_MACHINE32 path should redirect to.
My Win7x64 has the following:
Everything is INHERITED from MACHINE\Software\Wow6432Node
Users - read (this key and subkeys)
Administrators - Full access (this key and subkeys)
System - Full access (this key and subkeys)
Creator-owner - Custom (everything checked) (Subkeys only)
Best regards,
Mike Kaganski
thanks 1 user thanked mikekaganski for this useful post.
on 17/03/2016(UTC)
#8 Posted : 17 March 2016 05:04:26(UTC)
Thanks Mike, I will check. If Smath is hidden so far deep,
somebody will have to explain me the square wheel. I know a square
wheel runs flat in arcs of cycloid.
#9 Posted : 17 March 2016 05:21:08(UTC)
mikekaganski
Good
If I'm right, the problem isn't with SMath itself.
From my system administration experience, I suppose the following.
Recent SMath may have changed its installation process to not only register its DLLs for system bitness (64 on 64-bit system), but also for 32-bit to prevent acccidental removal in some exotic cases. Or it could be vice versa: it could have earlier always written to 32-bit, and now it writes to both 32- and 64. That could be either Andrey's decision (absolutely correct, I must say), or a change of packaging software - doesn't matter.
However, problems sometimes happen with Windows Installer itself (the OS subsystem that manages installs/uninstalls) that RANDOMLY changes (ruins) registry keys access control lists (ACLs). In a homogenous environment, where ~70 PCs were installed identically, all had identical HW and SW componennts, and so on, once in maybe 1-1,5 years one will suffer from this problem, while all others are OK. And I had this with MS softwares (MSOffice, Live Communicator), AutoCAD, Russian program CTAPT, LibreOffice, etc. Just have to go and manually fix that... Sometimes the fix itself isn't easy, because the system won't let me: it doesn't give me required rights. Had to repeatedly take ownership - reset ACLs - take ownership - ...
Best regards,
Mike Kaganski
on 17/03/2016(UTC)
#10 Posted : 17 March 2016 06:41:02(UTC)
... like dancing with the bear: don't brush your teeth !
What to do? Read advice from experts ... Thanks
#11 Posted : 17 March 2016 07:59:03(UTC)
mikekaganski
Jean, I suppose yours is not "same thing", but a totally different case! You have SMath installed successfully, only Maxima plugin fails to function properly. I'm really sorry, I cannot help here: I know nothing about Maxima.
Best regards,
Mike Kaganski
on 17/03/2016(UTC)
#12 Posted : 18 March 2016 17:36:35(UTC)
RamonTavarez
Rank: Member
@Mikekaganski:
Thanks for your help! Clapping
I followed your instructions and SS v0.98.5918 installed OK! Good
@Andrey:
The problem was in my system. Blush Now everything is solved.
Thanks again for your support! OK
thanks 2 users thanked RamonTavarez for this useful post.
on 18/03/2016(UTC),  on 19/03/2016(UTC)
