Ciao Sergio, Originally Posted by: PompelmoTell Hello Davide, I have problems with the export XeLaTeX. First it is highlighted exception Proceeding is inhibited the choice of options Proceeding is nevertheless produced a tex file You must still add the following line in the markup to fill in XeLaTeX
\newcommand{\defeq}{\coloneq} % SMath 'define equal' symbol I see, seems something related to multithreading vs Forms. I have to ask Andrey, but I think that I have to remove the dialog from the save flow. Originally Posted by: PompelmoTell PS some addition function is not implemented, however, the qualitative result of the prints obtained is much higher than that of normal export pdf. I would hate a little if this project was abandoned The project is not abandoned, but you know, there are a lot of plugins and I have to find a little bit of time for each one. I'll implement the missing functions ASAP. Edited by user 05 April 2016 22:14:30(UTC)
Ciao Davide,
with regard to functions not implemented do not worry there is always the possibility to act manually (thank you for the tremendous efforts of multiple plugins). For the mistake the question is more annoying: Andrey hopefully give a solution.
PLUGIN UPDATED SMath Studio 0.97.5346 and later- SS 0.98: fixed crash on save due to the Forms vs MTA; - ODT, TEX files: added Command Prompt flags (see documentation in 1st post); - ODT, TEX files: added more functions (vectorize, Floor, Ceil, at, cases, ternary booleans, absolute-definition's functions), fixed glitches in functions' names in ODT files, minor fixes & improvements; - TEX files: all worksheet's metadata are now stored in the \doc***** variables;
Edited by user 08 April 2016 19:03:06(UTC)
| Reason: typo |
Hello the problem indicated in the post #141 has been resolved sergio
1 user thanked PompelmoTell for this useful post.
How can i download plugin or dll file and then install it to my PC and save .sm file in ODF, not in ODT (ODF Text document)? I need this to be a formulas that can easy edit in MS Word lately. Please, give straight link on plugin or help me to solve this promblem. kursach SG.sm (377kb) downloaded 47 time(s).Edited by user 07 June 2016 10:35:01(UTC)
| Reason: add file
@mayIcomeiN, здравствуйте To download and install it, you need to go to menu Tools->Plugins, there make sure that "Plugins" is selected in the left pane, then click the "Local Storage" button over the plugins list, select "Online Gallery" and find the plugin there. Select it, and click "Install" at the bottom of the window. If you want "ODF", but not "ODT", then there is no such thing as pure "ODF". There are a number of Open Document Formats available, among them: ODT for text documents, ODS for spreadsheets, ODP for presentations, ODG for drawings, etc. What do you need specifically? MS Word since 2007SP2 is able to open ODT, Excel understands ODS, ... so what do you need? I cannot tell if they will import formulas OK, but that's up to you to test. |
Best regards, Mike Kaganski |
Hello. If you may, please answer me in russian. There is no plugin "DataExchange" or similar with "odf,odt" in discription. I already have plugin who called "DataExchange", but he dont' do his own case in particular that announced there Originally Posted by: Davide Carpi I want the formula looks like this . But after i saved my file in .odt ( ODF text doc.) wordpad told me that there is content who was incorrectly displayed.When i tried to open file in Word (2007 version) it cant be open beacuse Translation: "Cant open file Office Open XML because of errors in his content"
Originally Posted by: mayIcomeiN? Hello. If you may, please answer me in russian. Хорошо Quote:There is no plugin "DataExchange" or similar with "odf,odt" in discription. Это потому, что ... Quote:I already have plugin who called "DataExchange" Если какой-то плагин уже установлен, он не отображается в диалоге, пока к нему не выйдет обновление (тогда он будет подсвечен). Quote:but he dont' do his own case in particular that announced there
I want the formula looks like this ...
But after i saved my file in .odt ( ODF text doc.) wordpad told me that there is content who was incorrectly displayed.When i tried to open file in Word (2007 version) it cant be open beacuse ... Translation: "Cant open file Office Open XML because of errors in his content" Это не плагин "не делает того, что заявлено", а хреново работает MS Office. То, что WordPad не может его прочитать - так он вообще мало что может. А вот 2007 версия офиса, в которой появилась впервые поддержка ODF, получила очень плохую репутацию за некорректную поддержку - Майкрософт тогда вообще обвинили, что они саботируют ODF такой поддержкой. Вот файл, открытый MS Word 2013 и пересохранённый в docx: kursach SG.docx (113kb) downloaded 39 time(s). |
1 user thanked mikekaganski for this useful post.
Благодарю за поддержку! Thank for help! Edited by user 07 June 2016 12:44:40(UTC)
The importData.ODS function does not work in SMath 0.98.6398 (error message: function not defined) Is the plugin not supposed to work in the latest beta? |
Originally Posted by: mkraska The importData.ODS function does not work in SMath 0.98.6398 (error message: function not defined) Is the plugin not supposed to work in the latest beta? Fixed, thank you! PLUGIN UPDATED |
PLUGIN UPDATED SMath Studio 0.98.6484 and later- Fixed open document format support under MONO;
Hello there, Is there a method for using round() with exportDataCSV? Perhaps I need to loop through the multi dimensional array and operate on each entry using round(), ahead of using exportDataCSV. Please point me in the right direction for a robust method. Tim
You can use a loop or vectorize() over the round function |
PLUGIN UPDATED SMath Studio 0.98.6484 and later- Fixed wrong numerical output;
Originally Posted by: Davide Carpi You can use a loop or vectorize() over the round function Utilities Matrix roundup_n.sm (25kb) downloaded 38 time(s).
Originally Posted by: Jean Giraud You can use a loop or vectorize() over the round function In the last Hermite polyline, it does not understand vectorising roun(col,n) over specific col ... done otherwise.
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 509 time(s) in 339 post(s)
I love SMath, I really do. But nothing can beat LaTeX if it is the print quality. Converted .sm to .tex with SMath Studio "Save As->TeX". Used MiKTeX, altered tex file a little bit and compiled with XeLaTeX. Just for fun. Regards tex.zip (98kb) downloaded 51 time(s).Edited by user 09 February 2018 14:27:19(UTC)
2 users thanked overlord for this useful post.
on 09/02/2018(UTC), on 09/02/2018(UTC)
Originally Posted by: overlord I love SMath, I really do. But nothing can beat LaTeX if it is the print quality. Used MiKTeX, altered tex file a little bit and compiled with XeLaTeX. Just for fun. Regards tex.zip (98kb) downloaded 51 time(s). This SMath/Latex conversion was mentioned long time ago - there is even Tex File Type plugin for SMath - see these posts. Regards, Radovan |
Thanks Radovan,
I had to mention I did the conversion with SMath. Equation conversion is very well actually. The overall result is very good but the page layout was not as it is should be. I did alteration only to page layout.
