7 Pages«<34567>
Offline bdrunagle
#81 Posted : 10 June 2016 10:51:55(UTC)
bdrunagle
Rank: Member
United Kingdom
Was thanked: 13 time(s) in 6 post(s)
Thank you Alvaro, thank you Davide.
I must have tried a semicolon (my separator) before because I recognise what happens after the first press:
cases(■;■;■;■)
but didn't try pressing a second time!
It works for me now! Biggrin
Thanks again
Brian
#82 Posted : 10 June 2016 17:14:59(UTC)
Hello Brian,
Visit this great apllication, if it works for you.
It does not work anymore for me in the UNofficial 5346 relaese.
I concluded from multiple observations that the UNofficial
release came with a TimeStamp of so long duration so that past
the "date" it does not work anymore. In Smath 5346, this work sheet
did work properly for several days in multiple PC ON/OFF, but not
anymore to my disatisfaction. I observed that one from Davide
and many more from Martin.
Convolution RC [Cases, Davide].sm (110kb) downloaded 78 time(s).
Offline bdrunagle
#83 Posted : 10 June 2016 18:42:58(UTC)
bdrunagle
Rank: Member
United Kingdom
Thanks for that Jean
I had a quick look at the "T - not defined" issue. There's a workaround for SMath 0.98.5997 by including the T variable in the h(t) definition, rather than in the plot (I think I've got the '-' signs right).
Convolution_RC update.sm (11kb) downloaded 82 time(s).
The formula in the plot doesn't look quite as you'd expect, but I think the answer's right.
Cheers
Brian
#84 Posted : 10 June 2016 19:40:57(UTC)
Oh ! Brian: you must complete the project.
#85 Posted : 11 June 2016 13:41:22(UTC)
I have no issues in 0.97.5346; I don't think there are timestamps, 99% is something wrong in the plugins (missing or wrong for that SMath Studio version, or some conflict between plugins). cases() in the "unofficial portable" as it is when you download it is in the plugin Functions' Extensions 0.0.5261.2193; even updating Custom Functions to the latest available for 5346 I can run the worksheet correctly (this contains cases too, so there might be conflicts in some cases?).
In latest nightly build instead:
- I need the Brian's workaround to make it working the first plot (might be something in the 2D plot itself, since T is defined on the canvas);
- f(t) doesn't work anymore... I guess it might be something related to the "isUndefinedArgumetnSupported" af latest APIs, but seems there isn't a way to enable it for functions with an undefined number of arguments.... Umnik
About Levemberg-Marquardt, you have to install NonlinearSolvers plugin manully form the extensions manager: http://screencast-o-matic.com/watch/cD1X6giD2p
Edited by user 11 June 2016 13:49:18(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#86 Posted : 11 June 2016 15:44:19(UTC)
Rank: Administration
on 11/06/2016(UTC)
#87 Posted : 11 June 2016 17:33:26(UTC)
Thank you Andrey!
Unfortunately doesn't fix the issue... Sad
#88 Posted : 13 September 2016 17:37:09(UTC)
PLUGIN UPDATED SMath Studio 0.98.6096 Nightly Build only Beta
- cases() inner logic refactored (now acts in the same way both for numerical and symbolical evaluation);
thanks 4 users thanked Davide Carpi for this useful post.
on 13/09/2016(UTC),  on 13/09/2016(UTC),  on 13/09/2016(UTC),  on 02/12/2016(UTC)
Offline frapuano
#89 Posted : 03 December 2016 18:46:30(UTC)
frapuano
Was thanked: 13 time(s) in 13 post(s)
Hi Davide,
I am trying to use the at(2) to try to evaluate a formula with several variables in one step.
OK this makes quite no sense ...but is in an attempt much more difficult to use a same symbolical equation obtained through a solve in different parts of a documents with different values of the variables without using each time the technique of the disable evaluation ( at least is the only way I have found to address this issue ... it doesn't exist a command that allow to reuse a symbolical equation after some assignment have been done to the values of the variables referenced in it ).
However in doing this I have seen a strange behaviour of the at(2) as herewith reported:
See my comments in the screenshot.
Franco
#90 Posted : 03 December 2016 20:39:56(UTC)
Hi Franco Good
Once the variables are unknown at the definition of eta, you can reuse it any times you need, just define again the variables' values (search it in the Dynamic Assistant, you see that no numeric values are stored); use Clear(...) if you need to show again the unknown names.
This is because in the second argument of at() you are using variables already defined, therefore at() reads "7700*'kg/{'m^3}≡7700*'kg/{'m^3}" instead of "ρ_sfera≡7700*'kg/{'m^3}" -> currently you have to use Clear(ρ_sfera); I plan to improve at() with progressive preprocessing, to reduce these kind of problems (and the error message too).
Edited by user 03 December 2016 20:41:35(UTC)  | Reason: Not specified
on 03/12/2016(UTC)
#91 Posted : 04 December 2016 05:08:01(UTC)
If you set your formula "mathematically"
[in this case as an implicit expression],
you will solve anywhere in the document
for any of the variable.
Offline frapuano
#92 Posted : 04 December 2016 15:30:10(UTC)
frapuano
The problem Joan was not to get a formula using the solve command but use the result of the solve in several places on a worksheet ( always the same equation obviously ) as happens in a book when you are explaining something using always the same expression but applying different values on the RHS variables.
I was worried that after using the 1st time an expression it was no more "live" for further usage with different values.
This till the explanation of Davide I was using the trick of the "Disable evaluation" ..but this is not very elegant and useful.
( to tell the truth I have used the clear ..but probably positioning it in an incorrect way because the result was not like the one shown by Davide )
Franco
#93 Posted : 06 December 2016 01:33:48(UTC)
In mathematics, there is solving & solving. Smath is generous
by itself and in Maple companionship, quite convenient for
teaching/publishing/engineering.
Visit some "solving" applications attached. Report what does
work or not clear.
Solve Maple Implict Expr.sm (49kb) downloaded 73 time(s).
on 06/12/2016(UTC)
#94 Posted : 13 March 2017 13:40:12(UTC)
PLUGIN UPDATED
- Abs() now is hidden from dynamic assistance and Functions dialog; consider this function deprecated and use vectorize(abs(...)) or a classic loop instead.
#95 Posted : 14 March 2017 00:59:51(UTC)
Not very clear as well as the remaining of your comment.
Smath functions are infinitely usable, including the solvers. Taking into account
what comes with the new demand and taking into account of that you are not repluging
something in a bloc that has turned red first
. Generally a failed solve bloc can't be
repaired, depending upon the kind of failure.
Smath as well as Mathematica, Mathcad suffers "shadow in the context" page 7.
A bit of MicMac in long work sheets collectors type.
SolveGEN.sm (103kb) downloaded 62 time(s).
#96 Posted : 28 April 2017 13:12:12(UTC)
PLUGIN UPDATED SMath Studio 0.98.6325 and later
  • Clear(...) removed (built-in and more powerful since SMath Studio 0.98.6325);
Edited by user 28 April 2017 13:35:42(UTC)  | Reason: Not specified
on 28/04/2017(UTC)
#97 Posted : 28 April 2017 17:09:42(UTC)
Tanks Davide,
The big question is if new version will allow
updating 6179 via downloading 'patches' ?
#98 Posted : 28 April 2017 19:33:42(UTC)
It is up to Andrey's choice. In theory built-in Clear(...) is coded inside SpecialFunctions.dll, so this plugin in particular could be compiled and shared thorough the extension manager for older versions, providing the core of the target version is still compatible. In practice this might introduce some problems at several levels; due to the progress in the core some built-in plugins might be more back-compatible than others or not at all (therefore some plugin might be able to go back up to version 0.97.xxxx and other to some more reccent 0.98.yyyy). This will raise other problems, such as solving bugs for multiple core+plugins combinations (community side it makes harder to help to identify and solve problems, dev side this drains time to develop and fix bugs for further versions) Umnik
#99 Posted : 16 August 2017 20:56:38(UTC)
PLUGIN UPDATED SMath Studio 0.98.6398 Nightly Build only
- added rgb2image(...) rgb2image.sm (15kb) downloaded 55 time(s).;
- image2rgb(...) speed improvements;
- refactoring;
Offline Alex M.
#100 Posted : 08 November 2017 23:15:10(UTC)
Alex M.
Hi Davide, ran across this error...
Guest (3)
Similar Topics
[Custom Functions plugin] cases SS6179 (Bugs & Problems)
by PompelmoTell 07/02/2017 19:14:23(UTC)
7 Pages«<34567>
