2 Pages12>
Offline frapuano
#1 Posted : 03 October 2016 09:27:50(UTC)
frapuano
Was thanked: 13 time(s) in 13 post(s)
Hi Martin, Davide
I am still working about Vectors and what make me wonder is why using symbolic optimization I do not have a correct result for what concern the dot product (Scalar product) of 2 vectors .
There is something that for sure I am missing ..or I am asking too much to Smath ( I was starting to try the same in WxMaxima , if it works with this tool probably using the Maxima plug-in it should work from within Smath too)
Franco
Edited by moderator 05 October 2016 00:42:46(UTC)  | Reason: discussion moved from this point on
#2 Posted : 03 October 2016 11:24:03(UTC)
At first glance seems a bug in symbolic evaluation...
vectors.sm (9kb) downloaded 31 time(s).
Online mkraska
#3 Posted : 03 October 2016 13:37:56(UTC)
I also think that it is a bug, has been introduced after 97.5737
#4 Posted : 03 October 2016 16:47:05(UTC)
Originally Posted by: frapuano Go to Quoted Post
There is something that for sure I am missing ..or I am askingtoo much to Smath
You are not asking too much to Smath, but you seem not to follow rules
that apply to 1D, 2D, 3D vectors. Those rules are prescribed by convention.
The rules are: Vector * function ... NOT the other way around.
Forum Franco Vector Rules.sm (104kb) downloaded 43 time(s).
Offline frapuano
#5 Posted : 03 October 2016 21:25:58(UTC)
frapuano
Umnik Sorry Jean but I am not able to understand your answer even reading the .sm file you attached.
I am not using/defining any function in my example I am just multiplying in a scalar way same vectors ..or at least I guess so.
Franco
#6 Posted : 04 October 2016 20:51:36(UTC)
Are you reporting that your Smath version does not open my attachment ?
In your example, you mutiply whatever Ax is by a vector. This produces nothing.
Let's assume to make it productive by having A(x):= fnct(x). This would be wrong.
You multiply vector by function [1D,2D,3D vectors] by [1D,2D,3D functions].
That's what the work sheet exemplies by universal maths rules "convention".
Take another example from your book, so more collabs can contribute.
Cheers, Jean
Offline frapuano
#7 Posted : 04 October 2016 23:44:55(UTC)
frapuano
Jean,
I am able to open your example but I simply do not understand the relationship of you example with the issue I am reporting.
As already stated I don't want with my calculations to come up with a number but I would like to see in Smath that the scalar product ( or dot product ) of 2 vectors is the sum of the products of the components on each axis i.e that what should comes up from the symbolic calculations of the product is what is highlighted in yellow herewith :
I don't know if this request is too much for the internal Symbolic engine.
Moreover despite what is shown in the Davide's e-mail I can't evaluate numerically the expression of vector A but I have the expression in red with the error message A.x is not defined ( even because it would be impossible to evaluate it numerically ..I guess or I don't understand clearly the meaning of the "=" operator ).
I am using Smath Studio 0.98 build 6103.
I am pushed to think that Smath does not recognize that the expression of A is the definition of a vector as well the definition of B; so that when I apply the dot vector operator on these structure doesn't happen anything and are not applied the correct simplification rules ( but this is just my modest opinion about what is happening ).
Franco
#8 Posted : 05 October 2016 00:27:55(UTC)
"=" is the evaluation symbol (may be numerical or symbolical); type = to request a numerical evaluation, CTRL+. to request a symbolic evaluation (the one in my screenshot), You can even change the requested evaluation by context menu (right click -> optimization)
P.S. I've moved here OT messages from the original topic.
Edited by user 05 October 2016 19:54:30(UTC)  | Reason: marked as fixed
on 05/10/2016(UTC)
#9 Posted : 05 October 2016 01:30:45(UTC)
Franco,
No matter what A,B,C will be, from the onset your attempt is wrong.
Why wrong ? You have valued e(x,y,z). So, the next WHATEVER can't
be [A,B,C]*e(x,y,z) but e(x,y,z)*[A,B,C]. That's what the work sheet
previousely attached demonstrates for the 1D, 2D, 3D applications.
I don't understand "projection on axes...". There are 24 ways of
representing a 3D axis sytem. Mathematica and Mathcad don't have
identical system. Smath has no 3D system except the one from
"CreateMesh" or its native 3D plot. The 3 orthogonal directions
result from "monkey business creation".
Offline Andrey Ivashov
#10 Posted : 05 October 2016 18:07:14(UTC)
Rank: Administration
Thank you!
Actually extremely serious bug found:
It can be any function, not only vector.
Fixed.
Regards.
on 05/10/2016(UTC),  on 06/10/2016(UTC)
Offline frapuano
#11 Posted : 06 October 2016 00:24:18(UTC)
frapuano
Hi Andrey
Thanks a lot for the new RC5 it improves on the previous one but I guess that there are still some refinements to accomplish ...if possible.
See herewith , hoping that I was able to explain correctly the issue .
Thanks again and best regards
Franco
Offline frapuano
#12 Posted : 11 October 2016 08:52:44(UTC)
frapuano
Sorry for bothering again on this topic but I guess that still some basic improvement has to be done in multiplying a number by a vector , see herewith:
what I guess is the correct behavior is shown in WxMaxima too
Davide,Martin what do you think about ?
Franco
#13 Posted : 11 October 2016 10:51:11(UTC)
I think this is not safe until you assume that every unknown is always a scalar (that might cause several troubles) or there is some way to declare the type of an unknown (scalar/matrix/vector).
About the previous post, by default SMath tries to returns the most compact result; I guess might be matter for the expand() function.
Edited by user 11 October 2016 10:54:45(UTC)  | Reason: Not specified
Offline frapuano
#14 Posted : 11 October 2016 13:34:00(UTC)
frapuano
Davide,
for what concern your 1st point I guess that instead of declaring a variable a similar result can be accomplished using a different operator .
In WxMaxima I see that the multiplication of a scalar by a vector is done using the "*" while the dot product of vectors is through "." ; in Smath there is just one operator for everything and this probably my be an issue.
Your 2nd point due to my ignorance is not very clear; at least to me the Smath result doesn't look the most compact one when I multiply something that should be a scalar by a vector.
Franco
Offline ndtma
#15 Posted : 11 October 2016 16:39:43(UTC)
ndtma
Sri Lanka
Just for information. I am not sure whether this is helpful.
Edited by user 11 October 2016 16:44:26(UTC)  | Reason: Not specified
on 11/10/2016(UTC)
#16 Posted : 11 October 2016 18:54:50(UTC)
Helpful in the "way to please". But from the onset this all Vector stuff is
WRONG, WRONG ....! From the onset you have a vector that could be 1D only,
that could be 2D, that could be 3D. From there apply the the rules:
vector*function. I Have posted a demo sheet for 1D, 2D, 3D
It won't work the other way around "function*vector" because the rules
"vector*function" is the rule, not commutative like 3-2 is not equal to 2-3.
As long as Smath is correct: it can rotate 2D, 3D by the rules rather than
by "user invented rules".
#17 Posted : 11 October 2016 19:06:31(UTC)
Why should there be more arguments ?
Offline frapuano
#18 Posted : 11 October 2016 20:55:35(UTC)
frapuano
Hello NDTMA,
yes your feedback is helpful , I do not use Mathcad but I see that its symbolic evaluation is correct and leads to a vector and the application of the Vectorize tecnique in Smath is a good approach to address my issue ( but to tell the truth I consider this a good tip more than a proper solution ) , need to study and understand it better, I have never used it extensively.
What make me wonder is what Mathcad uses to do the dot product of 2 vectors whose result is a scalar, it has to be something different from "." I guess ( probably a wrong guess)
Thanks a lot
Franco
#19 Posted : 12 October 2016 05:28:54(UTC)
#20 Posted : 12 October 2016 06:44:06(UTC)
Guest (2)
2 Pages12>
