14 Pages«<910111213>»
Offline omorr
#201 Posted : 24 October 2016 19:38:03(UTC)
omorr
Rank: Administration
Serbia
Thank you Davide Good ,
I wish you all the best, and hope this time we will have more success than before.
#202 Posted : 24 October 2016 22:48:15(UTC)
For sure very interesting but incorrect from the onset.
"splines" are not functions, just zombie interpolation.
You can't plug "zombie" in in a vector for ODEsolve or rk solve.
"simply deceiving because deceivingly simple"
Cheers, Jean
Forum Radovan Integral.sm (210kb) downloaded 45 time(s).
on 24/10/2016(UTC)
Offline omorr
#203 Posted : 24 October 2016 23:31:03(UTC)
omorr
Serbia
Jean,
I just wanted to point out that in spite of "zombies" which return numbers, we are sometimes forced to use root finding, optimization etc.
You also remind me to put some stress to the many examples you posted here regarding different splines including your comments about it. As you pointed out, splines being zombies or not - we often have to integrate, differentiate etc. using splines. I think there were some example of yours worth making plugin functions from them because, as we know, we often can not do that using the current spline functions inside SMath.
#204 Posted : 25 October 2016 06:49:16(UTC)
You are right Radovan,
Smath splines [ainterp, cinterp, linterp] are "canvas" plotting
and on-line evaluation. They don't create a function thus can't be
use to integrate directly. You have two alternatives:
1. Dicretise/integrate finites differences
2. Transit via Infinitesimal modules
I went as far as I could in the attached. Plotting the components.
The "solve" block fails miserably, why?
It attempts to retrieve back to the integral that Smath does not
produce. The "solve" does not interpret the integral transit because
the solve block is a foreign entity. The Mathcad find(x) looks incorrect.
It depends upon initialisation. In this case the worng checks right.
Though the Mathcad Given/Find is often robust, it failed 1000's times
in my 15 years Mathacd collab.
Mathcad plots your integral, smath does not, thus it reflects in the "solve".
Please don't hesitate to correct me if I can help more.
Cheers, Jean
Forum Radovan Integral.sm (193kb) downloaded 49 time(s).
Offline omorr
#205 Posted : 25 October 2016 08:43:38(UTC)
omorr
Serbia
Hello Jean,
The integral works form me (the recent SMath version)
solve() works for me as well
Why is this working for me and not for you - I do not know.
#206 Posted : 25 October 2016 16:07:02(UTC)
Simple: the solve block of your version is more robust
or the chained code less reactive ? The other curiosity
5346 official release ..... 120 sec
5346 UNofficial release.... 14 sec
I got used to solve failure, rescue dichotomy.
BTW: eval(,) is not needed for f1(x)[faster].
Thanks Radovan, your collaboration is most appreciated.
on 25/10/2016(UTC)
#207 Posted : 25 October 2016 16:20:54(UTC)
Chain code error confirmed.
on 25/10/2016(UTC)
Offline Alex M.
#208 Posted : 27 October 2016 06:02:41(UTC)
Alex M.
Davide,
Here is an unforunate example of FindRoot() being unable to solve a problems with units... While my very quick NR Line() solver works just fine.
I wonder if we run into max + number problem or devision by zero.
Hoping for a fix!
FindRootBug.sm (12kb) downloaded 52 time(s).
thanks 2 users thanked Alex M. for this useful post.
on 27/10/2016(UTC),  on 27/10/2016(UTC)
#209 Posted : 27 October 2016 10:26:45(UTC)
Not sure why it fails in 1.0/1.1, but will works in next version Good
#210 Posted : 27 October 2016 15:16:03(UTC)
No matter who is getting what: As is not defined
on 27/10/2016(UTC)
Offline omorr
#211 Posted : 27 October 2016 17:10:42(UTC)
omorr
Serbia
Actually, it could be done - but setting the initial conditions for FindRoot() could be very troublesome for this example.
Initial conditions are chosen just on trial and error, and the calculation can diverge easily by slight changing of IC.
This is basically a second order polynomial having two solutions.
FindRootBug-corr.sm (17kb) downloaded 47 time(s).
Offline kilele
#212 Posted : 27 October 2016 17:55:32(UTC)
kilele
Excuse the off-topic: Could IC be readjusted iteratively depending on the expected results of the solution? IC auto-exploration so to speak. If solutions tend to behave like this then change IC like that,etc
thanks 1 user thanked kilele for this useful post.
on 27/10/2016(UTC)
Offline Alex M.
#213 Posted : 27 October 2016 18:12:28(UTC)
Alex M.
Is there a reason why solver would gravitate to wards a solution further from initial guess? If it were just to follow the slope at the initial guess value it would arrive to the closer, and in my case correct, solution
So far in my expirience it is almost always possible to make FindRoot() solve by substituting just the right value. There has to be a reaon why the function tends to overshoot nearest solution by so much. Also when it does not find a desired solution, the number it spits out is not always a mathematical solution either
Edited by user 27 October 2016 18:35:38(UTC)  | Reason: Not specified
thanks 1 user thanked Alex M. for this useful post.
on 27/10/2016(UTC)
Offline omorr
#214 Posted : 28 October 2016 08:30:42(UTC)
omorr
Serbia
We might say that often some numerical procedures (especially nonlinear) may "go nuts" sometimes and give the unrealistic solutions. Therefore, we have to have the ability to use few of them for the same task. In this plugin there are many procedures for root finding we could use beside FindRoot(), but they are not working at the moment (or I do not know how to use them anymore).
#215 Posted : 28 October 2016 10:41:14(UTC)
IC are a very sensible parameter in nonlinear solvers; you might know in advance an expected "order of magnitude" and the results still diverge because locally the function is too much or not enough steeper (or because there is another solution close).
For single variable problems I plan to add these algorithms, in which solutions are bounded in a range. Even, I guess would be possible to add some kind of "filter" to discard some solution (however, would be a replacement for something that should be done in any case: sanity check if the result fits personal needs).
Edited by user 28 October 2016 10:51:44(UTC)  | Reason: Not specified
on 28/10/2016(UTC)
Offline omorr
#216 Posted : 28 October 2016 10:56:38(UTC)
omorr
Serbia
This is exactly I was talking about - many different methods for the same task.
It would be very encouraging (less frustrating I hope) to have all those methods at our disposal as functions incorporated in plugins .
Best Regards,
Edited by user 28 October 2016 14:36:35(UTC)  | Reason: Not specified
#217 Posted : 29 October 2016 02:17:19(UTC)
Thanks Davide: I fell in love with SIG !
Yes Radovan: a "Peak/Deep/Root" in the menu would be great,
c/w different options. As robust they will look at the design
stage, they will not be so. Read again "ULP".
Going back to "FindRoot": as it looks in similar applications,
it is same or so Mathcad, a very universal code. For the free
finding solutions, IC must be either 0 or 1 [1 to releive from
"divide by zero"]. In examples [1,2] notice the switch of the
solutions. Be careful as it may scrap the project !
Examples [2, 3], Quaternion and Frobenius are robust and correct.
I didn't completely understand Alex example/problem. A case of
constrained IC difficult to handle and prone to fail.
Cheers, Jean
Solve Given_Find [UN test Robutness].sm (32kb) downloaded 49 time(s).
Solve NON-Iterative SIG.sm (45kb) downloaded 47 time(s).
Edited by user 29 October 2016 06:10:45(UTC)  | Reason: ethic publishing
thanks 2 users thanked Jean Giraud for this useful post.
on 29/10/2016(UTC),  on 29/10/2016(UTC)
Offline omorr
#218 Posted : 29 October 2016 17:37:11(UTC)
omorr
Serbia
Just for the record (especially for Davide) FindRooot() just does not work in the recent SMath for few of your examples with the error like in the picture. Actaually, it does work when you change the IC from zero to some other values.
on 29/10/2016(UTC)
#219 Posted : 29 October 2016 18:24:52(UTC)
Good
Edited by user 29 October 2016 18:27:17(UTC)  | Reason: Not specified
on 29/10/2016(UTC)
#220 Posted : 29 October 2016 20:14:57(UTC)
That's not a bug Radovan:
=>...For the free finding solutions, IC must be either 0 or 1
[1 to releive from "divide by zero"]<= ... {previous message}
Maybe you are not up to date vs Davide ?
Guest (2)
