Fixed. In your definition of Pu_Mu right above you had M.u instead of M.U. Not sure why it cause a crash. But now it runs. Masonry - STR - Out-Of-Plane - Wall - V1.sm (199kb) downloaded 28 time(s).FYI, the way I fixed this was to disable auto calculation. Then I scrolled down and disabled evaluation of each graph. I enabled the graphs one at a time and manually recalculated each time. The left one caused the crash. When I only enabled the right graph, it produced the error showing M.u was undefined. Then I could find the bad definition from there. Edited by user 02 February 2017 19:16:14(UTC)
2 users thanked alyles for this useful post.
on 03/02/2017(UTC), on 03/02/2017(UTC)
Here, it does not crash but the work sheet is red from top to bottom.
