Offline RFreund
#1 Posted : 02 February 2017 17:18:47(UTC)
RFreund
United States
See attached SMath calc. There are a pair of graphs at the bottom but I can't scroll to see them. The SMath page freezes.
Any thoughts?
Masonry - STR - Out-Of-Plane - Wall - V1.sm (199kb) downloaded 28 time(s).
Thanks,
Edited by moderator 03 February 2017 10:34:05(UTC)  | Reason: tagged
Offline alyles
#2 Posted : 02 February 2017 19:11:07(UTC)
alyles
United States
Fixed. In your definition of Pu_Mu right above you had M.u instead of M.U. Not sure why it cause a crash. But now it runs.
FYI, the way I fixed this was to disable auto calculation. Then I scrolled down and disabled evaluation of each graph. I enabled the graphs one at a time and manually recalculated each time. The left one caused the crash. When I only enabled the right graph, it produced the error showing M.u was undefined. Then I could find the bad definition from there.
Edited by user 02 February 2017 19:16:14(UTC)  | Reason: Not specified
thanks 2 users thanked alyles for this useful post.
on 03/02/2017(UTC),  on 03/02/2017(UTC)
#3 Posted : 03 February 2017 05:45:11(UTC)
Here, it does not crash but the work sheet is red from top to bottom.
