SMath makes my job as a mechanical engineer easier. It creates much more presentable calculations which are easier to follow (compared to a Matlab script or Excel spreadsheet).
more...
by Albert
La aparición del proyecto Smath, cubre un vacío que existía en el ámbito del software gratuito para Ingeniería. Es un proyecto que llegó para quedarse, ya que permite logros muy buenos a quienes utilizan esta herramienta. felicitaciones a Andrey y el gran equipo de colaboradores que cada uno con su aporte desinteresado hacen crecer esta aplicación que ya podemos caratular como de uso profesional
more...
by Ing Parcelo Ortiz Plá
A great and essential application for scientists and engineers. The updates are regular and it has plugins that make it complete and as powerful as the paid applications.
more...
by Yibbou
Edited by user 26 May 2017 00:43:13(UTC)
on 26/04/2017(UTC), on 26/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 27/04/2017(UTC), on 28/04/2017(UTC), on 29/04/2017(UTC)
Originally Posted by: Andrey Ivashov Built-in function Clear(..) implemented to remove variables/units/functions defined above on the Worksheet; Function Clear(...) previously available in Custom Functions plugin removed from that extension (from this version of SMath Studio onwards) Edited by user 28 April 2017 13:37:08(UTC)
Joined: 28/04/2017(UTC) Posts: 2 Was thanked: 1 time(s) in 1 post(s)
Due to wrong dpi detection, the user interface is inconsistent, the Contents of the ui Areas are too snall and don't match the actual pointer Location. The screenshot is made on a win10 13" macbook pro with definitly not 96dpi.
Originally Posted by: letzm Due to wrong dpi detection, the user interface is inconsistent, the Contents of the ui Areas are too snall and don't match the actual pointer Location.
The screenshot is made on a win10 13" macbook pro with definitly not 96dpi. I guess you have to remove image region plugin. |
1 user thanked letzm for this useful post.
Clear() doesn't work with vectorize(), whereas IsDefined() does. It is not really essential to have that feature but the response indicates successful execution, which is wrong. Clear.sm (30kb) downloaded 50 time(s). |
Hello Martin, Clear(,)=1 looks a Matlab code that clears the work space from previous assigned values. Thus, it renders the algorithm of the "work space" scalar wrt their respective scalar running iterators x, y ... In the attached "Fourier Quantum"... x,y are returned scalar only for the double integrator. The Mathcad double integrator is coded implicit of 'x,y' scalar ... much simpler but less educative. Jean Fourier Quantum CoC Copy.sm (98kb) downloaded 57 time(s).
