Offline Janusz
#1 Posted : 10 May 2017 15:40:04(UTC)
Janusz
Poland
I propose to add the new feature: a component is visible or not visible. It should depend on, for ex., result of the function "if". If calculation_type=1 then (dw is visible) and (gw is not visible) else ... This option will allow to make the display of the data elements dependent on the type of the calculation element. p.s. Very nice and useful software!
#2 Posted : 10 May 2017 19:49:55(UTC)
The way I interpret you demand is like:
conditional compute/not compute.
In some way we have that already.
How to code invisible ? Hello Gurus !
Visible.sm (13kb) downloaded 48 time(s).
Offline alyles
#3 Posted : 11 May 2017 22:00:41(UTC)
alyles
United States
I think this exists as a plugin. Check out conditionally formatted labels plugin. More info here: http://en.smath.info/for...ly-Formatted-Labels.aspx
thanks 1 user thanked alyles for this useful post.
on 12/05/2017(UTC)
#4 Posted : 12 May 2017 02:33:29(UTC)
Ah ! The forum has crashed for me.
Can't see all previous messages [Martin, Davide ...]
Image Spot True_False.sm (32kb) downloaded 30 time(s).
#5 Posted : 12 May 2017 05:12:01(UTC)
... added simpler spot, neat.
Image Spot True_False.sm (48kb) downloaded 35 time(s).
#6 Posted : 12 May 2017 17:12:33(UTC)
Hello Janusz,
Please, give more hint of what you wish. Previous replies vanished in the wind.
By default, some component(s) don't compute.
"Pixels not in the Map are black because undefined elements matrix are zero by default".
If it works for you: increase "kmax, kkmax" [my 1.6GHz very slow].
Pattern Cahos 4150 [RGB].sm (95kb) downloaded 25 time(s).
Offline Ernesto
#7 Posted : 14 May 2017 21:50:38(UTC)
Ernesto
Nicaragua
Was thanked: 13 time(s) in 11 post(s)
Janusz,
A limited way of doing this is to right click your if statement (or any operation) and deselect "Display input data".
This leaves you with only the result printed out.
#8 Posted : 15 May 2017 12:33:05(UTC)
The "if/otherwise" is common in Engineering. A less common "if"
is the the "on error", implemented as "try/on error" [6179].
In some other way, it is a "compute/not compute" component(s).
Visit this gorgeous application. 7min [1.6 GHz micro laptop.
Image Rotate RGB.sm (350kb) downloaded 27 time(s).
Few things have changed in the forum ! ?
#9 Posted : 15 May 2017 13:07:43(UTC)
... compute/not compute can be "bolean" too .
Random fill this Gaussian region.
Random Fill Range PDF.sm (40kb) downloaded 31 time(s).
Guest (2)
