2 Pages12>
#1 Posted : 12 April 2016 20:46:51(UTC)
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
  • installation: SMath Studio: Tools > Plugins... > Online Gallery (be sure to have the "Exclude beta-versions" unchecked);
  • documentation: (beta) Run Example.7z (5kb) downloaded 194 time(s)..
Beta >>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<< Beta
Edited by user 17 November 2018 19:37:28(UTC)  | Reason: badges
thanks 5 users thanked Davide Carpi for this useful post.
on 12/04/2016(UTC),  on 12/04/2016(UTC),  on 12/04/2016(UTC),  on 13/04/2016(UTC),  on 13/04/2016(UTC)
Offline ElSid
#2 Posted : 12 April 2016 22:09:25(UTC)
ElSid
United States
Will this allow us to transfer data? SWEET!Clap
Only thing better would be not needing to use data propagation between the worksheets (e.g. using rfile,
wfile, importData, exportData, ...).
Edited by user 12 April 2016 22:35:15(UTC)  | Reason: Not specified
#3 Posted : 13 April 2016 20:21:48(UTC)
Is more targeted to process data "remotely"; data transfer is driven by existing functions (also include());
Only thing better would be not needing to use data propagation between the worksheets (e.g. using rfile, wfile, importData, exportData, ...).
I think the only other way, in the scenario drawn in the example of the first post, would be to transfer data via functions, that is not a feasible way as for now.
Also, I have to improve the log system to better recognize if there are errors in the target worksheets. Umnik
Edited by user 13 April 2016 20:23:39(UTC)  | Reason: Not specified
Offline ElSid
#4 Posted : 15 April 2016 23:12:30(UTC)
ElSid
United States
How is this different than "Include" plug in by Uni?
#5 Posted : 16 April 2016 18:39:42(UTC)
Mainly:
include() loads the SMath variables/functions from the target worksheet into the one in use, while in Run() each worksheet is indipendent;
include() can't run non-math regions (ComboBoxList, etc...) while Run() execute everything;
Offline ndtma
#6 Posted : 27 August 2016 08:28:06(UTC)
ndtma
Sri Lanka
Originally Posted by: Davide Carpi Go to Quoted Post
  • requirements: SMath Studio 0.98.5935 or later;
  • Problem in 98.6081?
    #7 Posted : 27 August 2016 14:48:06(UTC)
    Hello collab ndtma,
    Don't take my comment bad. Your snippets are always blurry [not comfortable].
    You can "PrintScreen" paste in Paint to select the portion. That results in
    huge BMP... then reduce to 256 via IrfanView: superfreeware of multiuse ...
    mostly: sharpen image, superbe Lanczos zoon [square/rectangular] gray/color
    images ++++ .
    I use this technique as well as capture a selected region from WinGrab
    [freeware]. Wingrag has more options to reduce 256 colors, in many difficult
    cases of better quality than IrfanView, though is does not apply to Smath snippets.
    Cheers, Jean
    Offline ndtma
    #8 Posted : 27 August 2016 16:10:59(UTC)
    ndtma
    Sri Lanka
    Hello Jean,
    Thanks for your valuable suggestions.
    #9 Posted : 27 August 2016 16:29:53(UTC)
    Originally Posted by: ndtma Go to Quoted Post
    Problem in 98.6081?
    Hello ndtma,
    yes, seems there are isSies with the process handle. I'm looking to find the cause and if I can solve it Umnik
    Edited by user 27 August 2016 23:56:46(UTC)  | Reason: typo
    #10 Posted : 29 August 2016 19:05:21(UTC)
    Issue found.
    edit: fixed in SS 0.98.6179
    Edited by user 02 December 2016 02:42:03(UTC)  | Reason: fix not included in latest relase
    Offline ksullivan
    #11 Posted : 01 November 2018 21:30:04(UTC)
    ksullivan
    Hi Davide, I created my own example with a 3x3 excel table and it takes about 6 seconds for the "Run" function to execute each row of test data during the for loop. The smath sheet it's running contains 2 variables multiplied together and output as a variable 'd'. Your entire example runs in 22 seconds, with definitely a bit more complexity, but not much. Any ideas here? I'd like to run 400 rows of data (load cases for different members) through a calc sheet and collect the results, just like you've done (except only one calc sheet, not 3 like you've done).
    thx!
    Edited by user 02 November 2018 20:02:00(UTC)  | Reason: Not specified
    #12 Posted : 02 November 2018 13:24:46(UTC)
    Currently each Run function triggers a new instance of SMath Studio; this means that all the initialization process must be done every time, rising the execution time. What you can try is to change the logic to start a single run with multiple worksheets, and init/finalize each loop step in a dedicated file.
    new loopSheet.sm
    initCalc.sm
    handleCalcResults.sm
    Edited by user 02 November 2018 14:25:30(UTC)  | Reason: Not specified
    on 02/11/2018(UTC)
    Offline ksullivan
    #13 Posted : 02 November 2018 20:32:57(UTC)
    ksullivan
    Thanks for the response Davide.
    So I went ahead and tried out your idea, it does solve the only 'running' once issue and finishes the script in 6 seconds no matter what.
    But now I have the issue where the Run(exec) command does not seem to be running all the scripts in the exec matrix, or somehow it's only saving the first 'calcResults' in 'allResults'. That said, I was successful in manually looping the 3 sheets, so I thin something is going on incorrectly in the run(exec) line.
    You can see what I did in the gifs below if you open them full size in a new tab..
    Thoughts?
    Calc completed successfully by manually looping the 3 sheets:
    Manual loop method works
    Calc running with loop sheet, only records first row result:
    #14 Posted : 02 November 2018 21:52:52(UTC)
    Originally Posted by: ksullivan Go to Quoted Post
    so I think something is going on incorrectly in the run(exec) line.
    That I don't understand the idea/purpose of run does not indicate it is useless.
    Do you mean run would calculate in a cash of some sort a selection of work sheets
    and then would show all calculated by clicking "Open file" ?
    Offline Razonar
    #15 Posted : 03 November 2018 00:21:03(UTC)
    Razonar
    Uruguay
    Thoughts?
    Hi K. Gif shows that you modify iniCalc.sm (disabling some calcs) but don't save it, so others SMath files read the original iniCalc.sm, not the modified. Is this the issue or I'm are not understanding something else?
    Offline ksullivan
    #16 Posted : 03 November 2018 06:05:52(UTC)
    ksullivan
    I reran it after saving everything and the same thing happened..here's a non-gif image and the files. I guess Davide's example ran fine so I should be able to figure this out haha. I'm currently troubleshooting so stay posted Good
    testCalc.sm (4kb) downloaded 34 time(s).
    handleCalcResults.sm (6kb) downloaded 32 time(s).
    initCalc.sm (10kb) downloaded 35 time(s).
    input.xlsx (9kb) downloaded 32 time(s).
    loopSheet.sm (11kb) downloaded 30 time(s).
    This gave me what I want..
    Run(exec)
    Run(exec)
    Run(exec)
    I quit, there's something with run() only running files if they have a different name, or the Run(exec) is called again (like above). I created a new, simpler example.. Below shows that if exec is defined with 3 separate but identical calc.sm files (calc1.sm, calc2.sm, etc) then run(exec) will run all 3 files and the allResults var is fully populated. If I define exec as a vector with all the same calc.sm files then it won't work and allResults will just end up with the first result.
    calcSheet.sm (6kb) downloaded 28 time(s).
    loopSheet.sm (6kb) downloaded 27 time(s).
    Edited by user 03 November 2018 08:39:47(UTC)  | Reason: Not specified
    #17 Posted : 03 November 2018 21:46:07(UTC)
    You are right, I have to investigate it. Umnik
    #18 Posted : 04 November 2018 02:54:20(UTC)
    Document calcSheet calculates nothing [no maths/formula(s)/result(s)]
    Certainly no gadget will retrieve something from nothing, is it ?
    If calcSheet calculates something, save to file and retrieve from
    any other Smath work sheet. On the other hand, you may save formula(s)
    in calcsheet and retrieve from any other Smath work sheet then modify
    the formula(s) in the working document ... per say change parameters.
    You say nothing about what you have in mind.
    Offline ksullivan
    #19 Posted : 04 November 2018 04:54:49(UTC)
    ksullivan
    I know in this case calcSheet.sm is not "calculating" anything. The whole problem we're trying to solve is looping a large data set through the calcSheet, row by row, which processes the data with whatever formulas we want, in this case it's 1*data Good my previous example actually took one of the values in the 'current row' and multiplied it by 3. I just wanted to make the example here as simple as possible so we could hone in on the problem.
    #20 Posted : 04 November 2018 18:38:23(UTC)
    I know in this case calcSheet.sm is not "calculating" anything. The whole problem we're trying to solve is looping a large data set through the calcSheet, row by row, which processes the data with whatever formulas we want, in this case it's 1*data my previous example actually took one of the values in the 'current row' and multiplied it by 3.I just wanted to make the example here as simple as possible so we could hone in on the problem.
    Simply attach the basic project and describe the next part of the project.
    As you explain, it looks weird from maybe baby simple.
    Guest (2)
    Similar Topics
    Euler works - Runge-Rutta not (Questions)
    by OchkovVF 31/12/2023 06:02:28(UTC)
    RSgoldfast RuneScape: Jagex has put a lot of alarm (Download SMath Studio)
    by Guest 30/11/2023 16:48:33(UTC)
    Cannot run in Ubuntu 22.04 (Download SMath Studio)
    by vroberts 28/09/2023 21:57:49(UTC)
    HELP WITH PROGRAM RUNTIME (Questions)
    by JReg 03/06/2023 12:52:38(UTC)
    Form running on worker thread and not main thread (Questions)
    by fakemoses 28/05/2023 00:26:25(UTC)
    ist "Lifetime"-Lizenzierung auch für Advanced Version verfügbar? (Project discussion)
    by andrbig77 03/06/2022 15:00:01(UTC)
    runyvmat.com (Extensions)
    by tang190 25/05/2022 09:14:22(UTC)
    What's the Difference between a Start and a Run Capacitor? (Features announcements)
    by hunian157 30/03/2022 04:59:00(UTC)
    Smath Now Doesn't Run - Suspended? (Questions)
    by lmariam 13/03/2022 20:20:40(UTC)
    slow running (Questions)
    by roman111 01/02/2020 19:31:45(UTC)
    Trunc(Number,part), mantissa(X), csgn(z) (Samples)
    by Jean Giraud 28/08/2019 15:38:33(UTC)
    Saving Runtime (Questions)
    by RegCurry 11/03/2019 09:23:03(UTC)
    SMath Error Running Lubuntu 18 (Questions)
    by dmmartinez 19/10/2018 23:57:32(UTC)
    Run exe file in DOS from Smath (Questions)
    by Oscar Ugaz 09/07/2018 19:39:58(UTC)
    New version (0.99.6646) does not run (Bugs & Problems)
    by Basile 14/03/2018 03:16:12(UTC)
    2 Pages12>
