Was thanked: 21 time(s) in 17 post(s)
Hi!
At the moment I cannot drag any object from the template pane to the modeller region. I am using 0.99 (6839) But you can test it easily by opening the example in the first post online. There it doesn't work, too. Also the tooltip by hovering the any template objects appears only rarely.
Editing already exiting objects works fine.
kind regards, Martin
Originally Posted by: MarB At the moment I cannot drag any object from the template pane to the modeller region. From the 5 years ago # post, it looks like Modeller was left in limbo. 6179 has no object in the template pane... just a dead cumbersome region of no use for real projects.
Originally Posted by: MarB I am using 0.99 (6839) But you can test it easily by opening the example in the first post online.
Or offline:
Originally Posted by: MarB I am using 0.99 (6839) I can reproduce Martin example [some comments added]
The "Drag and drop" function is not working. I have downloaded an examples with modeller region and I can move/change shapes in modeller but I can't add new shapes from templates bar. Does anybody can help ?
Originally Posted by: Dominik Skrycki I can't add new shapes from templates bar. I can't add new shapes from templates bar.You can only add shapes that you have created or borrowed from unknown sourcesIn this document, two objects were created and installed in the template N =5 => yellow square N 13 => light gray dodecagon Check if it works in your SS version modeller-demo-Kr.sm (16kb) downloaded 65 time(s).
Thank you Jean for help. I have opened your document and I see that 3 shapes (2 dodecagon and 1 square) have you added to moddeller work space from template bar. But I can't select and add any shape from template. As I said - drag and drop function not works. One more thing. I have downloaded "RainboGame.exe" and drag and drop function works fine. But it has not work in "exe" files created by me. Edited by user 19 November 2018 09:46:12(UTC)
Originally Posted by: MarB At the moment I cannot drag any object from the template pane to the modeller region. Originally Posted by: Dominik Skrycki The "Drag and drop" function is not working Updated, please try now. Edited by user 19 November 2018 12:03:01(UTC)
Thank you Davide for help. Now I can drag and drop shapes but I can't zoom in and out shapes using mouse scroll. Edited by user 19 November 2018 21:55:25(UTC)
You're welcome Originally Posted by: Dominik Skrycki Now I can drag and drop shapes but I can't zoom in and out shapes using mouse scroll. You can only zoom the modeller canvas, not the single shapes (even in previous versions). P.S. another update made because templates weren't detected on mouse move (no template name shown, f.e.) Edited by user 20 November 2018 02:52:20(UTC)
Originally Posted by: Davide Carpi You can only zoom the modeller canvas, not the single shapes (even in previous versions). SS 6179, zoom is by handles and thus fabricate otherwise than native. 1. The blue line come automatically 45° ... make it as thick as desired. 2. The arrow, you can rotate at will from the creation. Observe the the empty "" fill arrow 3. Fill color applies to closed shapes 4. for some weird figure it can be done by digitizing and collecting the XY vector. Modeler takes only pairwise XY vector ... not matrix modeller-demo-Kr.sm (28kb) downloaded 40 time(s).
... Airfoil added Observe => [5*Airfoil,"red",2,clr] modeller-demo-Kr.sm (40kb) downloaded 35 time(s).
... streamlines added around airfoil Some cleanup needed ... modeller-demo-Kr.sm (134kb) downloaded 54 time(s).
Originally Posted by: RFreund Is there anyway to have the center of the modeler canvas moved so that (0,0) is not at the center? Maybe YES ... in the attached objects are disposed/located. modeller-demo-Kr.sm (163kb) downloaded 30 time(s).
Originally Posted by: RFreund Is there anyway to have the center of the modeler canvas moved so that (0,0) is not at the center? AFAIK, not as you state it. Why do that ? 1. Slide the shape [circle] in the canvas. 2. Click-in to see the dotted frame [3 big black dots per side] 3. Double click to get the coordinated [X,Y]...[0,0 = centered canvas] ...width/height for circle/ellipse ...size the shape [zoom ±]. If you have some difficulties ... please don't hesitate.
... you can toy things for an all evening demo. modeller-demo-Kr.sm (165kb) downloaded 25 time(s).
Jean, in your example you could specify an appropriate default size of the objects. Then the arrow template doesn't appear as a single dot any more. |
Yes, but to make it interactive, you need slider regions. Use a function as predefined layout. It's third and fourth arguments are channels to convey the canvas co-ordinates. The canvas is centered at these co-ordinates, evaluated for the default scale. The default scale is given by the second entry of the dependent layout row vector. Modeller%20-%20Shapes%20-%20Canvas%20Center_Kr.sm (14kb) downloaded 47 time(s). |
on 03/01/2020(UTC), on 10/04/2021(UTC)
Originally Posted by: mkraska Jean, in your example you could specify an appropriate default size of the objects. Then the arrow template doesn't appear as a single dot any more. Thanks Martin, most appreciated ... updated. modeller-demo-Kr.sm (163kb) downloaded 79 time(s).
