4 Pages<1234>
Offline MarB
#41 Posted : 03 November 2018 16:28:11(UTC)
MarB
Was thanked: 21 time(s) in 17 post(s)
Hi!
At the moment I cannot drag any object from the template pane to the modeller region.
I am using 0.99 (6839)
But you can test it easily by opening the example in the first post online. There it doesn't work, too.
Also the tooltip by hovering the any template objects appears only rarely.
Editing already exiting objects works fine.
kind regards,
Martin
#42 Posted : 04 November 2018 19:40:54(UTC)
From the 5 years ago # post, it looks like Modeller was left in limbo.
6179 has no object in the template pane... just a dead cumbersome
region of no use for real projects.
Offline MarB
#43 Posted : 04 November 2018 21:44:19(UTC)
MarB
Or offline:
#44 Posted : 05 November 2018 04:27:36(UTC)
I can reproduce Martin example [some comments added]
Offline Dominik Skrycki
#45 Posted : 18 November 2018 21:53:18(UTC)
Dominik Skrycki
Poland
The "Drag and drop" function is not working.
I have downloaded an examples with modeller region and I can move/change shapes in modeller but I can't add new shapes from templates bar.
Does anybody can help ?
#46 Posted : 19 November 2018 03:11:55(UTC)
You can only add shapes that you have created or borrowed from unknown sources
In this document, two objects were created and installed in the template
N =5 => yellow square
N 13 => light gray dodecagon
Check if it works in your SS version
modeller-demo-Kr.sm (16kb) downloaded 65 time(s).
#47 Posted : 19 November 2018 09:35:00(UTC)
Dominik Skrycki
Poland
Thank you Jean for help.
I have opened your document and I see that 3 shapes (2 dodecagon and 1 square) have you added to moddeller work space from template bar.
But I can't select and add any shape from template.
As I said - drag and drop function not works.
One more thing.
I have downloaded "RainboGame.exe" and drag and drop function works fine.
But it has not work in "exe" files created by me.
Edited by user 19 November 2018 09:46:12(UTC)  | Reason: Not specified
#48 Posted : 19 November 2018 12:00:38(UTC)
Updated, please try now.
Edited by user 19 November 2018 12:03:01(UTC)  | Reason: Not specified
#49 Posted : 19 November 2018 19:18:05(UTC)
Dominik Skrycki
Poland
Thank you Davide for help.
Now I can drag and drop shapes but I can't zoom in and out shapes using mouse scroll.
Edited by user 19 November 2018 21:55:25(UTC)  | Reason: Not specified
#50 Posted : 20 November 2018 02:37:39(UTC)
You're welcome Good
You can only zoom the modeller canvas, not the single shapes (even in previous versions).
P.S. another update made because templates weren't detected on mouse move (no template name shown, f.e.)
Edited by user 20 November 2018 02:52:20(UTC)  | Reason: Not specified
#51 Posted : 20 November 2018 03:21:08(UTC)
SS 6179, zoom is by handles and thus fabricate otherwise than native.
1. The blue line come automatically 45° ... make it as thick as desired.
2. The arrow, you can rotate at will from the creation.
Observe the the empty "" fill arrow
3. Fill color applies to closed shapes
4. for some weird figure it can be done by digitizing and collecting the XY vector.
Modeler takes only pairwise XY vector ... not matrix
modeller-demo-Kr.sm (28kb) downloaded 40 time(s).
#52 Posted : 20 November 2018 04:05:03(UTC)
... Airfoil added Observe => [5*Airfoil,"red",2,clr]
modeller-demo-Kr.sm (40kb) downloaded 35 time(s).
#53 Posted : 20 November 2018 04:32:35(UTC)
... streamlines added around airfoil
Some cleanup needed ...
modeller-demo-Kr.sm (134kb) downloaded 53 time(s).
Offline RFreund
#54 Posted : 31 December 2019 22:23:50(UTC)
RFreund
United States
Is there anyway to have the center of the modeler canvas moved so that (0,0) is not at the center?
See attached.
Modeller - Shapes - Canvas Center.sm (12kb) downloaded 47 time(s).
#55 Posted : 31 December 2019 23:33:43(UTC)
Maybe YES ... in the attached objects are disposed/located.
modeller-demo-Kr.sm (163kb) downloaded 29 time(s).
#56 Posted : 01 January 2020 06:02:19(UTC)
AFAIK, not as you state it. Why do that ?
1. Slide the shape [circle] in the canvas.
2. Click-in to see the dotted frame [3 big black dots per side]
3. Double click to get the coordinated [X,Y]...[0,0 = centered canvas]
...width/height for circle/ellipse ...size the shape [zoom ±].
If you have some difficulties ... please don't hesitate.
#57 Posted : 01 January 2020 06:51:16(UTC)
... you can toy things for an all evening demo.
modeller-demo-Kr.sm (165kb) downloaded 25 time(s).
#58 Posted : 03 January 2020 16:04:16(UTC)
Jean, in your example you could specify an appropriate default size of the objects. Then the arrow template doesn't appear as a single dot any more.
#59 Posted : 03 January 2020 16:47:42(UTC)
Yes, but to make it interactive, you need slider regions. Use a function as predefined layout. It's third and fourth arguments are channels to convey the canvas co-ordinates.
The canvas is centered at these co-ordinates, evaluated for the default scale.
The default scale is given by the second entry of the dependent layout row vector.
Modeller%20-%20Shapes%20-%20Canvas%20Center_Kr.sm (14kb) downloaded 46 time(s).
2020-01-03 14_33_43-SMath Studio 0.99.7251 - [Modeller%20-%20Shapes%20-%20Canvas%20Center.sm_].png
on 03/01/2020(UTC),  on 10/04/2021(UTC)
#60 Posted : 03 January 2020 18:00:42(UTC)
Thanks Martin, most appreciated ... updated.
modeller-demo-Kr.sm (163kb) downloaded 78 time(s).
Guest (2)
Similar Topics
RC section in modeller region (Samples)
by Renzorex 26/02/2022 19:03:23(UTC)
Vertical text in modeller region (Extensions)
by Renzorex 25/05/2021 21:56:39(UTC)
4 Pages<1234>
