They talk about us
excelente programita lo recomiendo
more...
by malandro
Es un programa excelente y muy útil para la enseñanza y aprendizaje en ing. Civil. Muy recomendable!!!
more...
by Wilson Rodríguez Calderón
Es un imprescindible para el día a día. Muchísimas gracias Mr Andrey Ivashov.
more...
by Ángel Álvarez
on 08/03/2021(UTC), on 08/03/2021(UTC), on 09/03/2021(UTC), on 10/03/2021(UTC)
Joined: 28/08/2014(UTC) Posts: 1,370 Was thanked: 829 time(s) in 525 post(s)
Hi. Thanks for the program, and this update. An small issue: Write some text and then put the cursor somewhere in between within that text and hit the right-delete key. When you reach the end of the text, the work DELETE begins to appear several times: Best regards. Alvaro.
Originally Posted by: Razonar I can easily reproduce it. What a funny bug, can't keep myself to print several DELETE. Somebody stop me
Yes. Edited by user 08 March 2021 15:39:06(UTC)
Oops... I did it again I've spent so many time on backward compatibility, performance and formatting improvements... even forgot to check the simplest use cases. Sorry. Will fix it asap. Actually I'm starting to prepare to make a stable release, so I do not plan to do any major code changes until it is done. Small fixes/corrections only. Thank you!
on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 27/03/2021(UTC)
