This is a must have software for engineering student.
more...
by Rabbi
Dentro del ámbito de la investigación y desarrollo electrónico es una herramienta completa para realizar los análisis preliminares y más. / Within the field of electronic research and development, it is a complete tool for preliminary analysis and more.
more...
by Cristian Matorra
Excellent tool for electric engineering.
Must have portable software on your USB key. Symbolic calculations is a great value for electronics.
more...
by Igor Skarine
on 08/03/2021(UTC), on 08/03/2021(UTC), on 09/03/2021(UTC), on 10/03/2021(UTC)
Hi. Thanks for the program, and this update. An small issue: Write some text and then put the cursor somewhere in between within that text and hit the right-delete key. When you reach the end of the text, the work DELETE begins to appear several times: Best regards. Alvaro.
Joined: 23/07/2013(UTC) Posts: 1,128 Was thanked: 509 time(s) in 339 post(s)
Originally Posted by: Razonar I can easily reproduce it. What a funny bug, can't keep myself to print several DELETE. Somebody stop me
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
Yes. Edited by user 08 March 2021 15:39:06(UTC)
Oops... I did it again I've spent so many time on backward compatibility, performance and formatting improvements... even forgot to check the simplest use cases. Sorry. Will fix it asap. Actually I'm starting to prepare to make a stable release, so I do not plan to do any major code changes until it is done. Small fixes/corrections only. Thank you!
on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 09/03/2021(UTC), on 27/03/2021(UTC)
