#1 Posted : 09 July 2012 11:50:04(UTC)
Hi all Good
In this snippet there are several functions to work with units:
- Extracting Unit of Measurement
- Calculate Order of Magnitude
- Rounding
- Truncate
- Floor
- Ceiling
best regards,
w3b5urf3r
known limitations: because 0 in SMath have no units, so UoM() return 1 every time the argument is set to 0*anyPossibleUnit
snippet updated: see reply #4
Edited by user 26 July 2012 15:25:48(UTC)  | Reason: Not specified
File Attachment(s):
units.sm (24kb) downloaded 111 time(s).
units_examples.sm (45kb) downloaded 96 time(s).
thanks 4 users thanked Davide Carpi for this useful post.
on 09/07/2012(UTC),  on 09/07/2012(UTC),  on 09/07/2012(UTC),  on 09/07/2012(UTC)
Offline kilele
#2 Posted : 10 July 2012 17:06:44(UTC)
kilele
Thank you very much for these useful functions!!
Could be possible a function to remove units from an equation in order to apply Solve ?
please look at
http://en.smath.info/for...52_solving-equation.aspx
#3 Posted : 10 July 2012 19:07:46(UTC)
please look at
happy to be useful Wink
Actually I think the simplest way it's to insert units inside the "expression" argument of solve() (see the attachment)
regards,
w3b5urf3r
Edited by user 10 July 2012 23:09:22(UTC)  | Reason: Not specified
#4 Posted : 25 July 2012 00:32:19(UTC)
please look at
snippet updated!
now there are uSolve.2(#) and uSolve.4(#) to reproduce solve(2) and solve(4) with units
see the attachment for the usage
regards,
w3b5urf3r
Edited by user 25 July 2012 00:34:20(UTC)  | Reason: Not specified
File Attachment(s):
units.sm (31kb) downloaded 73 time(s).
units_examples.sm (62kb) downloaded 66 time(s).
on 25/07/2012(UTC),  on 25/07/2012(UTC)
Offline kilele
#5 Posted : 25 July 2012 01:15:02(UTC)
kilele
Thank you sir for sharing your scripts, I didn't respond to your last post because I wanted to find the time to understand it well.
Is this usolve function able to deal with equations involving multiple units as in the example I cited above ?
#6 Posted : 25 July 2012 02:40:02(UTC)
Hi kilele Good
This snippet is a "little workaround" so have some limitations:
- uSolve.2(#) and uSolve.4(#) first argument must be a single-argument function
- uSolve.2(#) need the third argument to know the unit of measurement of function argument
however, taking care of these limitations, inside the function you can use multiple units and the input and output units may be different (see the attachment, introduced in the new unit_examples.sm re-attached in the post above)
regards,
w3b5urf3r
Edited by user 25 July 2012 02:43:02(UTC)  | Reason: Not specified
Offline kilele
#7 Posted : 25 July 2012 04:52:09(UTC)
kilele
wow I am very much obliged to you ^^ this is really useful
so the second parameter of usolve2 is also the desired output unit ? in my case the following samples always output meters:
usolve2(f(x),5 m, m)=9.96 m
usolve2(f(x),5 m, mm)=9.96 m
usolve2(f(x),5 m, cm)=9.96 m
Edited by user 25 July 2012 04:56:33(UTC)  | Reason: Not specified
#8 Posted : 25 July 2012 14:15:10(UTC)
The third parameter provide only the kind of unit (mass,length,force,pressure,etc..), the desired output unit must be set in the right side, after the evaluation (see the attachment)
regards,
w3b5urf3r
Edited by user 18 September 2012 01:35:39(UTC)  | Reason: Not specified
